One side has two positions for the tie rod, the other looks like its been plugged. My friend's '79 only has one position--the quicker (shorter) one. Has anyone seen this plug(?) before? What would be the point of plugging it?
So in the past I heard the front hole was for quicker steering - and I guess it will - But with Manula steering, you might need a bit of muscle to turn the steering wheel.
So a more accurate statement would be you get quicker steering using the front hole (less travel distance), but if you use it for a manual setup, it is not the standard and is hgarder to turn.
