LONGSHOT pic request
Old May 24, 2007 | 11:28 PM
randommj's Avatar
randommj
Default LONGSHOT pic request
does anyone hav a pic or the light sensor thats hooked up to the "head lamp" light in the gague clustor? and would i be able to relocate it or put a schimm under it, be when i hit bumps it goes off, im thinking its good, just misplaced
Miles
Old May 25, 2007 | 05:18 PM
randommj's Avatar
randommj
bump
Miles
Old May 25, 2007 | 05:53 PM
NHvette's Avatar
NHvette
Sounds like the micro switch that is mounted to the headlight assembly.
http://www.zip-products.com/Zip/prod...9FC6FA8EC1AD88
Probably not a defective switch ... sounds more like the headlight cover
bouncing around. More likely headlight cover bushings or weak actuator.
Old May 25, 2007 | 06:48 PM
Duke94's Avatar
Duke94
The switch is on the left just below center. Is that the part you are looking for. This is from my 71'
Old May 25, 2007 | 07:55 PM
randommj's Avatar
randommj
GREAT!!!! thxx for that!, it looks as tho it can b moved forward a bit, am i right
Miles
Old May 25, 2007 | 10:45 PM
randommj's Avatar
randommj
thats wut i needed but
DIAGNOSSIS TIME!!!!! when there closed is when i looked under there at the sensor, i realized that the sensor dosent touch ANYTHING when its in the dwon possition, so what could be causing my "head lamp" light to be constantly on, untill i hit a bump, then if flickers on and off........i thought it was the sensor, but it touches nothing
Miles
Old May 26, 2007 | 07:54 AM
...Roger...'s Avatar
...Roger...
Miles
That switch works in the up or open position not the down position.That switch provides a path to ground but is not used when the headlights are down.I think the problem is in the headlight switch.Its pretty simple the light on your dash has 2 wires going to it.One is the light blue and it is hot only when the headlight switch is on.The other is white with a dark green tracer and that is the ground for the light.The w/dg wire is always grounded until the headlights are in a full up position.----The LB wire must be getting 12 volts on the bumps causing the light to flicker.Hope this helps.
Old May 28, 2007 | 12:21 AM
randommj's Avatar
randommj
so where is the LB wire getting the 12 volt, just a bad switch letting volts through when its jared? or a bare wire somewhere?
Miles
Old May 28, 2007 | 07:42 AM
...Roger...
Miles
My guess would be a bad switch but if you unplug the connector at the headlight switch and it still does it then I would look into your bare wire theory.If it doesnt do it then its a bad switch because thats where the LB originates and gets its 12 volts.The ground side of the headlight warning light is supposed to be grounded until the headlamp bucket is in the full up position.
Old May 28, 2007 | 07:50 PM
7T1vette's Avatar
7T1vette
You will have to find where the electrical "break" is occurring in your wiring system. It could be a faulty: headlight switch, sensor switch, a a broken power wire, or a faulty ground connection. Use an inexpensive volt-ohmeter to determine which is at fault.
Old May 29, 2007 | 09:38 AM
taylorsk8's Avatar
taylorsk8
Can someone explain more about the sensor, my left side one is broken and dangling from the wires. What is happening because it is broken off? Does it change anything in the lights or in the lift mechanism. I hav bugs in my headlight system and I guess this could be the problem.
T
Old May 29, 2007 | 09:50 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
T
The switch turns on the headlamp warning light on your dash. When you pull the headlight switch, there will be a redlight on the dash until the headlights reach the full up position and then the warning light will go out.
Lights off.
Lights on.
Old May 29, 2007 | 12:46 PM
7T1vette's Avatar
7T1vette
Your "dangling" switch is accidentally closing at random, which makes the dash light go out. Reinstall the switch correctly, or purchase a replacement and install it per the A.I.M.
Old May 29, 2007 | 02:43 PM
taylorsk8's Avatar
taylorsk8
So it only affects the dash light not the opeation of the lift or actual head lamps. Does this mean if the sensor is working the headlamps won't come on if the healdights are down?
T
Old May 29, 2007 | 10:15 PM
randommj's Avatar
randommj
T
it just affects that light on ur gague cluster to be illuminated or not, no biggie unless urs is ALWAYS on and annoying the EVER LOVING PEE WADDIN POOP out of you!
(im workin on finding the "break" n the line)
Miles
To LONGSHOT pic request
