Help ! 3 threaded holes ?
Old May 25, 2007 | 11:14 PM
FLPLAYTIME88's Avatar
FLPLAYTIME88
Default Help ! 3 threaded holes ?
I picked up a 77 from a guy that had stored it in the barn for the last 12 years ..in pieces.. i have got it running and have done most of the body work... my quiestion... 3 threaded holes at the top rear of both windows.... i cant see any thing in any pictures bolted in that spot... just under the t-tops
your help would be great
first time corvette driver
frist time restorer
first time post
Steve
Old May 25, 2007 | 11:51 PM
Jclgodale3's Avatar
Jclgodale3
T-top latch plates?
Old May 25, 2007 | 11:57 PM
FLPLAYTIME88
t-tops latch inside these are outside
Old May 26, 2007 | 12:00 AM
VETTEVIC's Avatar
VETTEVIC
Where the triangle stud sticks out, that the back of the t-top sits on. Heres a link to a pic of the parts.
Type in in317k for a picture.
http://www.bairs.com/search.asp
Old May 26, 2007 | 12:03 AM
7T1vette's Avatar
7T1vette
If you are talking about the pillar behind the side [door] windows, the holes are for the adjustment plate which locates the rear outer corner of the T-tops. The smaller holes on the bottom are for the adjuster plate; the big hole is for the triangle-headed screw on which the T-top sits.
Old May 26, 2007 | 12:05 AM
Jclgodale3's Avatar
Jclgodale3
Old May 26, 2007 | 12:12 AM
FLPLAYTIME88
thanks i will dig though the 4 boxes ...now i know what i'm looking for
..it looks to be trim..as my t-tops line up and are tight with out them
To Help ! 3 threaded holes ?
