what does this do ?
Old May 31, 2007 | 10:16 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
Default what does this do ?
i am wondering what the lever and cable do that goes from the column in the engine compartment down to the transmission linkage. what is it for? this is on a 75 with a th400.
Old May 31, 2007 | 10:21 AM
1970's Avatar
1970
I believe it looks the steering wheel when you put the transmission in park.
Old May 31, 2007 | 10:23 AM
1970's Avatar
1970
I meant locks
Old May 31, 2007 | 10:32 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
the wheel will turn when the car is in park as long as the key is in it. so i dont think that is it.
Old May 31, 2007 | 11:00 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
it is supposed to be the shifter lock, kepp you from taking it out of park without the key, when it works
Old May 31, 2007 | 11:27 AM
SIXFOOTER's Avatar
SIXFOOTER
When it works
Old May 31, 2007 | 01:01 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by 1970
I meant locks
This board does have an "edit" function...
Old May 31, 2007 | 01:08 PM
MikeMc71's Avatar
MikeMc71
LOLOL......taht si os funyn....oops
Old May 31, 2007 | 03:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No disrespect, but why not purchase the 75 assembly instruction manual and find out what it does. The AIM has a diagram of the assembly and the original part numbers.
Knowledge is power.
Old May 31, 2007 | 03:15 PM
moosie982's Avatar
moosie982
Knowledge is power.
Very true, but we are here to help our less fortunate( Unlearned ) brethren and let them know WTF a part does so they then can go beyond what we have taught them That cable locks the trans in park untill you insert the key and unlock it, " Is knowledge learned by asking any less knowledge then by finding out yo' dam self" buy a book and learn when the summer repeats wear you down. Peace,,,Moosie
Old May 31, 2007 | 03:41 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
thanks for the info, i am considering swapping to a 2004r trans so i was making sure it would still be needed when i did the swap.
Old May 31, 2007 | 03:51 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
Knowledge is power.
thanks for your great reply it really helped answer my simple question. it's this kind of responce and attitude that is killing this forum. i do have a manual that has covered most everything i have done on the car but it only has a pic of the assy. and does not explain the function, so i thought i would ask here as this forum is sometimes a great place to get simple answers. sometimes you just have to wade through all the to get them though.
Old May 31, 2007 | 04:34 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
200FRCF that is the column interlock cable and its function is to
lock the key into the ignition until Trans is placed in Park.
Dual function of the interlock is to lock the steering wheel so it cant be turned unless key is in the on position.
Sounds like your cable needs to be adjusted or its disconnected somewhere.
If the wheel can be turned without key in ignition it sounds like the wheel lock pin (in the column ) is missing. The lock pin is driven directly by the ignition lock cylinder.
If you can take a look in the service manual and It'll show all that stuff in the column
Old May 31, 2007 | 05:22 PM
NHvette's Avatar
NHvette
Knowledge is power.
I've read all my AIMs.
Nowhere that I have seen ... does the AIM describe the operation of the steering interlock cable.
This is false information. Please do not disseminate further.
Here is some info that may actually be HELPFUL :
Jim Shea is the resident steering guru. He has many many papers at corvettefaq.com.
Here is the interlock paper:
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
Here is a list of all his papers:
http://jimshea.corvettefaq.com/?page_id=4
Hope this helps get your interlock working or removed without problems.
In a nutshell, the interlock forces you to put the car in Park (auto)
or Reverse (manual) before removing the key.
Old May 31, 2007 | 11:28 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
thanks for the explaination guys. i now know the real answer as to what it does. i knew someone would know the answer. thanks for the links!
To what does this do ?
