Automatic Or Manual Frame
Old Jun 5, 2007 | 09:42 AM
toupstrio's Avatar
toupstrio
Default Automatic Or Manual Frame
Can an automatic frame be used in place of a manual transmission frame? What is different about them if they can't be swapped? Are the frames the same from 74-79?
Old Jun 5, 2007 | 09:51 AM
markdtn's Avatar
markdtn
Yes, an auto frame can be used in place of a manual. Auto frames have removable crossmembers.
Old Jun 5, 2007 | 10:41 AM
toupstrio's Avatar
toupstrio
Old Jun 5, 2007 | 10:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by toupstrio
Can an automatic frame be used in place of a manual transmission frame?...
Auto in place of manual....Yes, provided you swap out the clutch bracketry if you want a manual transmission.
...What is different about them if they can't be swapped?...
The clutch goodies. 68-79 manual transmission frames have the clutch bracketry welded to the frames. 80-82 manual frames have the bracketry bolted in place. Automatic frames do not have the cluth hardware.
Old Jun 5, 2007 | 12:57 PM
72LS1Vette's Avatar
72LS1Vette
There is only 1 bracket that needs to be welded on the auto crossmember so it's not a big deal to use an auto frame. IMO, the convenience of the removeable crossmember is a big plus with an auto frame, if you're not concerned about originality.
Rick B.
Old Jun 5, 2007 | 02:14 PM
Stumpdeisel's Avatar
Stumpdeisel
If you're planning to use a hydraulic clutch the factory clutch rods and mounting points will not be needed.
And yes, a removable crossmember is nice to have...
Old Jun 5, 2007 | 02:42 PM
toupstrio's Avatar
toupstrio
Thanks everyone for the input I did not know I could use an auto frame.
Old Jun 5, 2007 | 06:32 PM
copter's Avatar
copter
You probably allready no this but just forgot.No 82 manuals.
Old Jun 6, 2007 | 02:11 AM
67-73-76's Avatar
67-73-76
74 and 79 frames are not the same.
74 was a 1 year only frame. The rear cross member that the bumper mounts to is different than every other year.
In addition the side rails behind the rear wheels are not the same shape.
73, one year only.
74, one year only.
75-77 probably the same. May be slight difference because later cars had steel floor pan.
78-79 are the same. Different rear bumper mount cross member than 75-77 cars
To Automatic Or Manual Frame
