Painters in So. Cali
Old Jun 6, 2007 | 04:42 PM
Busrydr's Avatar
Busrydr
Default Painters in So. Cali
Okay, I've seen some really nice paint jobs on Vettes. And there are many, many Vette specialty shops in So. Cali that can hook me up. But generally (and I'm not slamming them) those specialty shops charge a specialty price for the love and care they provide.
Does anyone have experience with a painter in So. Cali that can do a relatively good job without me having to get a second mortgage to pay for it?
The car will have all of the exterior trim, rear bumpers and vents removed and interior panels, carpet as well as all weather stripping. Total color change and not much in the way of the prep and painter.
Thanks for any input.
Old Jun 6, 2007 | 05:18 PM
Scott Marzahl's Avatar
Scott Marzahl
Did you try J&D Corvette in Bellflower? Did you do a forum search on "Macco". Some of these Macco shops have some excellent spray guys that are willing to paint off hours etc with quality paint.
Old Jun 6, 2007 | 06:38 PM
Busrydr's Avatar
Busrydr
Yep, I tried J&D. They were the last option before I posted on the forum. Again, most of those specialty shop do great work, but they charge for the fact that the Corvette is a special vehicle. Let's face it if a VW was made of fiberglass would it cost $10K to get it painted?
Old Jun 6, 2007 | 10:37 PM
Corvettes White's Avatar
Corvettes White
It would still be a slug bug.
George
Old Jun 6, 2007 | 11:23 PM
Sayfoo's Avatar
Sayfoo
I was in your position about 8 mos. ago. J&D does do good work, but $5k just for plain paint is rediculous. I went to 1 Day paint in Long Beach. Scott, the mgr., drives a super stock Dodge and appreciates old cars. Their top of the line paint job is $1400, and with a color change and underside of grills, etc. , I spent about $1900. It is not quite as good as J&D, but probably 95%, and a hell of a lot better than stock. Most people don't believe I didn't spend more. I believe they use Dupont Nason paint. Not the top of the line, but good. I would use them again.
Old Jun 7, 2007 | 12:57 AM
JIM's Avatar
JIM
So Cal is a big area. Where are you at?
Old Jun 7, 2007 | 04:01 AM
Busrydr's Avatar
Busrydr
I'm out in the IE. I know that fiberglass seams must be treated and I have an OEM rubber nose that needs special care. But I just want a nice paint job that is not going to crack or fade for a long while. I'm even doing all the trim removal and installation.
Glenkov48, you have a street or this paint shop? I can look it up and give em a try.
Old Jun 7, 2007 | 09:02 PM
Sayfoo's Avatar
Sayfoo
2035 E. Carson, L.B. 562 424-7195. Ask for Scott. You might check the 1 day shops by you also, as it really all depends on the management. It appears that the important part is buffing out the clear coat. The rest is not rocket science. Good luck. Check their web site.
Old Jun 8, 2007 | 06:19 AM
Busrydr's Avatar
Busrydr
Thanks, I'll give them a shout.
Old Jun 8, 2007 | 08:55 AM
big_G's Avatar
big_G
Specialty painting shops have a reputation to protect. They use high-end paints and employ skilled craftsmen. They charge what is necessary to keep the doors open. The "1" day painting operations have no rep. to protect. They don't care if you ever come back, or bad-mouth their shop. They have a much larger market, do low-end work, and charge accordingly. They make their profit on low quality, high volume. You still get what you pay for.
Old Jun 8, 2007 | 10:55 AM
SoCalErv's Avatar
SoCalErv
Army
For $1,900 are they removing emblems, door moldings, etc painting then re-installing or just masking and spraying. The later does not give you the same result as it is not acceptable to have paint where it does not belong. I think a car looks terrible when you open the door and the molding and interior light switch is painted.
But if they remove, paint and re-install I would be interested.
Old Jun 10, 2007 | 12:09 AM
Sayfoo's Avatar
Sayfoo
This is generally true, but not always. I do know of $5k plus paint jobs that are not that good . Maybe I was lucky, but if you do the prep yourself you can get a good spray job, at a reasonable price. Also, everyone has different financial or personal situations. Is it really worthwile to spend $10k on body and paint work on a $10k daily driver?
Old Jun 10, 2007 | 05:22 PM
hdpete98's Avatar
hdpete98
Default san diego area painter
A C M Auto Body & Paint
1175 Y Industrial Avenue
Escondido, CA 92029
(760) 747-1628
I saw a 3 year old paint job on a 64 vette that still looked great.
Old Jun 10, 2007 | 10:50 PM
Sayfoo's Avatar
Sayfoo
No. The origional question stated that he would remove everything, inside and out. as I did. This is one way to save some money. Do it your self. Also, beside saving money, you will probably get a better job then the illegal alien of the day working to replace your emblems, etc.
To Painters in So. Cali
