Headlight Problem
Old Jun 7, 2007 | 05:35 AM
carlthecopyking's Avatar
carlthecopyking
Default Headlight Problem
My 75 coupe is acting very strange when I shut off the car the right headlight will rise all by itself along with the left side,they take turns.
I then have to start the car for them to drop. I have new headlight actuators installed.Any help much apprecdiated.
Old Jun 7, 2007 | 05:51 AM
corvetteload's Avatar
corvetteload
Headlight relay valve(s)
Old Jun 7, 2007 | 08:39 AM
Tommy Samuels's Avatar
Tommy Samuels
or a major leak in the signal circuit to the relay. It looses vacuum to the top of the relay while there's still enough in the reservoir to raise the lights
Old Jun 7, 2007 | 08:41 AM
...Roger...'s Avatar
...Roger...
With car running pinch off the small hose feeding both relays-what happens? nothing?Turn engine off(hose still pinched)what happens?
Old Jun 7, 2007 | 09:27 AM
jdp6000's Avatar
jdp6000
Diagram
Old Jun 7, 2007 | 10:50 AM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like the check valve is hosed.
Old Jun 7, 2007 | 01:56 PM
...Roger...
Default Bad Diagram
Originally Posted by jdp6000
Diagram
jdp6000 this diagram is wrong-the two hoses on the headlight switch are reversed.This could be why some guys are getting confused.
Old Jun 7, 2007 | 03:24 PM
Hammerhead Fred's Avatar
Hammerhead Fred
check valve located in the vac line right on top of the intake manifold.
It's supposed to be a one-way valve, when it begins to leak/goes south the headlights will pop-up as will the wiper door either upon engine shutdown or sometimes when you floor it.
Old Jun 7, 2007 | 04:33 PM
jdp6000's Avatar
jdp6000
Weird...its out of a book. Also been posted here many times.
Jim
Old Jun 7, 2007 | 09:59 PM
...Roger...
Jim
I know I got one just like it from Corvette-101.com.The port closest to the **** (#2)is the main vac source from the manifold.The other port(#3)goes to the pulldown.Here is one from a 69 that is correct at the switch.
This image was removed because the owner of the drawing got upset that it was posted,even though his business name ,phone number, state and city and part number was fully visible.
To Headlight Problem
