Front Bumper Body Work
Old Jun 7, 2007 | 09:48 PM
rfoster19's Avatar
rfoster19
Default Front Bumper Body Work
I have a ding on the nose of my front bumper of my 1980. What kind of Body filler should I use being it is rubber? Also can someone recommend a primer? Thanks for any help...
Old Jun 7, 2007 | 09:55 PM
Mikes*Corvettes's Avatar
Mikes*Corvettes
http://forums.corvetteforum.com/show....php?t=1718505
Old Jun 8, 2007 | 06:25 AM
crazywelder's Avatar
crazywelder
Transtar makes a lot of specialty auto body products and they have the 2 products you need and most paint supply stores carry these. Plasto-mend will repair your urethane bumper damage and with some practice works very well. Download the data sheet from the web site for instructions and prep work and use their cleaner. Also they have a water based primer, Hydroflex Waterborne Primer that works very well on urethane bumpers. It can be wet or block sanded and fills well but let it set 24 hours before sanding and recoating even though the instructions state otherwise.
I have found all of their products to be of good quality and much cheaper than the big brands.
http://www.tat-co.com/default.asp
Old Jun 8, 2007 | 08:02 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Be sure to use flex primer (i.e. primer suitable for urethane) (all this 2 part stuff puts off alot of nasty vapors DO NOT SPRAY IN YOUR basement, the voice of experience.) Go to a local auto paint supply shop. If they are not interested in helping you get the right stuff, go somewhere else. Stick with same manufacturers products. Piece of cake to fix.
Good luck, let us know if you need more help
tt
Old Jun 8, 2007 | 09:50 AM
Kyle69-71 BBs's Avatar
Kyle69-71 BBs
I fixed a 70 gto nose with fuzor (SP)?
It is a two part system in a tube.
They make a lot of stuff,this is made just for bumpers and came in a purple tube.cost $30
Its sandable and paintable
To Front Bumper Body Work
