I found this paint at pepboys.
Its spray on caliper paint and looks decent. I painted my rotor hubs with it.
I had to replace all 4 calipers so i went with VBP O-ring powdercoated red, then did some dremel work and used POR-15 high temp engine red and some high temp engine white paint to do the lettering and fillings.
From: Minnesota in the summer, Las Vegas in the winter
The IBB (international brotherhood of Bubbas) has met, discussed the matter at hand, and has unanimously voted to approve the above procedure............
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
i really like your paint work. A question about your wheels though. Is it my imagination or are your wheel studs different lengths? Now that would be Bubba!
You can take a rubbing of your caliper face on a piece of paper to get the correct arc of the caliper so you know what angles the letters have to be to fit on the caliper. Then go to a local sign shop and they will have the C5 font stored or can be found easily on their internet resources. And have them do the lettering that will fit in the shape of your caliper. Wasn't expensive at all. Make a few extra copies incase you error. Its easier to get the letters that remain on your caliper and you paint over to do the outside but mine were already powdercoated so I had to carefully apply the vinyle sticker and pull off the letters and paint them on.
Plain calipers from VBP, had to grind off the "Delco" embossing then paint over with a similar red (yes Ford Red looked the best)
Applied the entire sticker and pulled off the letters with an exacto knife and forcepts.
Painted the lettering with hi temp white paint and let dry.
Went over the edge of the letters with the exacto knife then carefully pulled the sticker off. All that should remain is the white letters. Some touch up was required.
Took about a day or two b/c i had to wait for the paint to dry.
Haha, that car is on jack stands. I only threaded the lug nuts on a few turns so the wheel stayed on while I took the pics. Some lugs went a little further then the others. Studs are ARP 1/2" x 3".
Originally Posted by VettePower
I see what you mean about the stud lengths!!
My question is though, why arn't you using some better looking lug nuts??
Your Calipers are great!!!!!
In speaking with a few wise vette owners who also track their cars (not that I will, but track cars are overbuilt and safe) I decided to go with the longer studs and open ended lugnuts for maximum thread engagement. Closed-end lug nuts would have looked cooler but I had no idea how deep I would need them with the TTII's and the ARP studs and 5/16 adapters in front. The studs in the pic are only being used while I do my frame off. I have Gorilla open ended locking lugs that I will use on the car once its done (look similar). Then once I know the final dept that a closed end lug nut will need to be I'll look around.
