I have to replace the hose that comes off of the compresor on the A/C. I removed the old hose and now I was told by a friend that you can't just install the new hose and charge the system. You need to get the condensation out some how. Does anyone know the proper way to do this? I only want to do this once and not waste any product or money. Thanks to all in advance.
Charlie
Anytime you open the system, you need to replace the drier as it will load up with moisture within a hour. So replace the drier and hose and pull a 28hg vacuum on the system for an hour. This will boil out the moisture in the system. Verify that the system holds the vacuum for at least an hour and you can recharge.
They make vacuums for this, or a guy on eBay sells plans to use an old refrigerator pump to build one.
No offense, but it sounds like you don't know much about HVAC systems. Without manifold gauges and some know-how, you can cause a lot of problems - best bet is to take it to an A/C shop and make use of their expertise.
How about on 73-78ish cars that had the VIR system instead of the dryer. Can you just use the kit from napa and then put a vacuum on the system?
Correct Batman, Don't know much about HVAC systems but I am quite hand and mechanical. With the right tools and instructions I could handle it. Do they rent the vacuums at rental places? Does the system stay in the "vacuum" state when you disconect the vacuum? Is that all that needs to be done before recharging? Thanks for all the help people.
I don't know that much about auto HVAC, but I am a HVAC installer in residential and commercial buildings. I am not sure if the same thing applies to cars but, but first you might want to check for leaks by charging the system with nitrogen. If the nitrogen leaks, the refrigerant will to, so you need to fix the leaks. I have found that pulling a vacuum is not a guaranteed way to check the pressure of the system. Next evacuate all of the nitrogen and pull a vacuum with a vacuum pump which you can probably rent at a local HVAC supply house. That will pull all the contaminates out of the lines. Thats just my 2 cents.
There are quite a few old threads here about HVAC systems - there might be some info there that would help. Check the "Search!" thread in the Tech section for information on searching the archives.
From personal experience, I struggled with the A/C system in an old driver of mine because I didn't have a proper set of gauges. I had a terrible time getting the pressure right.
OK, here is where I am...I got the plans for the home made vacuum pump. I tested the fridge compressor and it only pulls 26 in Hg. Is that OK? Also, do I need to have the pump run for the hour that I am testing the Vette a/c system or can I disconect it after I get it to the 26 in Hg?
PS
I'm going to convert to R134a.
You need to pull 29 on a normal gauge for a long time. For my own stuff, I let it run overnite after I'm sure there are no leaks.
That is the only way you can boil off the moisture.
Moisture in AC is very very bad.
A thermister vacuum gage should really be used, water boils out at 1500 microns and you should try to get to around 600 microns.
