GRINDING...rear end
Old Jun 12, 2007 | 09:34 PM
FLPLAYTIME88's Avatar
FLPLAYTIME88
Default GRINDING...rear end
I just re-built e-brakes ... so that was the first place i looked... took the all the way out...not there...started thinking Differential... read all the threads... drained fluid and ran a magnet .... no metal.. u-joints seem to be tight... btw..no gring at all while tires are in the air....thinking rear bearings ... how do i test... and can i do this myself... chiltons ..no help with this...am i on the right track ?... anyone been here ?
thanks for any help
steve
Old Jun 12, 2007 | 11:02 PM
monza_man's Avatar
monza_man
I have the same problem right now too. Havent gotten into it much yet but I will let ya know about any progess I make.
Old Jun 13, 2007 | 09:43 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You should be able to hear a bad bearing. Get the rears off the ground and spin each tire in turn. Wobble test will also work.
Old Jun 13, 2007 | 12:50 PM
GD70's Avatar
GD70
What kind of sound would they make?
Old Jun 13, 2007 | 01:46 PM
monza_man's Avatar
monza_man
Mine have no wobble but make a metal on metal squeel when they get to a certain sport.
Old Jun 13, 2007 | 06:31 PM
schmegeggie's Avatar
schmegeggie
Jack up the rear, grab the wheel at the 12 & 6 o'clock position. If there is excess movement, the bearings are probably shot....mine were. The noise was intermittent, but when I turned around(i.e. u-turn), man! It felt like the wheel was coming off.
If not that, check the half shaft joints for movement.
If you just rebuilt the e-brake hardware, something might be loose, or a spring make be flopping around in there.
Good Luck!
Old Jun 13, 2007 | 06:39 PM
FRSTR90's Avatar
FRSTR90
Did you put the limited slip additive?
Old Jun 13, 2007 | 06:45 PM
FLPLAYTIME88
i just dropped it at a shop..i was told by 2 different transmition shop this was the guy to talk to... he jumped in and around the corner at slow speed..it felt like i was draging a 30lb vise...he said posi clutch... he will call tomarrow after he opens it up...i've never been in one of those...read some good posts about the subject.... i think it needs a pro...
Old Jun 13, 2007 | 06:47 PM
FLPLAYTIME88
limted slip aditive...yep
12 and 6 ...no movement
sound it make...clunk.clunk..ggrrriiinnndd..pop.. pop..gggrrriiinnnddd..clunk...or some thing real close
Old Jun 13, 2007 | 09:10 PM
Laffinlex6's Avatar
Laffinlex6
(My husband's (NitrousDean) comment: Sounds like the clutch plates in the posi aren't releasing... which is good for taking off; both wheels will bite in the asphalt. If you put the limited slip additive in, it should take a lot of the noise away but ocassionaly you might have one wheel hook up well and the other not as well... so maybe try 1/2 a bottle at first.
Old Jun 14, 2007 | 09:06 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by FLPLAYTIME88
i just dropped it at a shop.... he jumped in and around the corner at slow speed...he said posi clutch...
Never hurts to pay for expertise!! Posi clutches are a heckuva lot cheaper than rear bearing replacement.
To GRINDING...rear end
