seatbelt dye
Old Jun 15, 2007 | 09:34 PM
gator79's Avatar
gator79
Default seatbelt dye
has anyone had luck dying late model seatbelts? I have some late model F body belts for my 71 but the tan is not the same as mine. has anyone tried to dye them? has it held up? it would not be a total color change just a shade darker. I was thinking of the liquid corvette america/sems dye.
Old Jun 16, 2007 | 06:12 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
i dont know if that will work but i could tell you that on my 79 i had no luck with the ritz fabric you buy in the supermarket. gave it a try because it was cheap. but had no results. ended up sending them to ssnake-oyl.com for a reweb
Old Jun 16, 2007 | 09:24 AM
tak82's Avatar
tak82
I used the Ritz dye from Wally world to dye mine from GREY to RED. Dyed them twice and most washed out. It did turn them a shade of pink. I ended up spraying them with interior paint-dye from Corvette America. They were stiff at first but they've softened up, and they match the interior now.
Old Jun 17, 2007 | 03:02 AM
bluegtp's Avatar
bluegtp
gator79,
hey man, I acutally just did mine 2 days ago...they're stock 79 belts that were in tan....I 'm going with a black interior now, so of course i dyed them black....I've set them in the dye twice already and they're sort of a dark dark charcoal right now(which i can live with that)....
heres a hint though, when you use the rit dye....get some plastic gloves and pour it on the belt directly and kinda rub it in a little making sure you cover inside the loops and everything.....runs some hot water in a bucket/pan whatever....just enough to submerge them, and try and use as little water as possible....i added some salt even though it's not cottom...then stirred every 15 minutes or so a few times, then let sit over night....washed the excess dye out and now they're almost pure black....
If i get a free second tomorrow i'll take a picture of them, i've only done the lower "buckle" part so far.....
later man,
ryan
Old Jun 17, 2007 | 09:31 AM
gator79's Avatar
gator79
thanks Bluegtp I will try it, I have the complete set from the F body and I only need the rears so I can use the fronts to test
Old Jun 17, 2007 | 01:56 PM
redc3's Avatar
redc3
i used the rit dye and had great results. i went from grey to black and the only problem i found is that you need lots of drying time so the color wont rub on other interior parts
Old Jun 17, 2007 | 02:27 PM
skeptic's Avatar
skeptic
That's great news. I used Duplicolor on my interior to dye it from camel to black. I dyed the strap that holds down the T-tops and they look good but were stiff so I didn't want to do that to the seat belts. Now that I know they soften up after some use I'll definitely be doing that to the seat belts as well.
Old Jun 17, 2007 | 02:40 PM
gator79's Avatar
gator79
is there any difference between the liquid and the aresol dye from corvette america? I believe it is made by sems
Old Jun 17, 2007 | 03:02 PM
Kyle69-71 BBs's Avatar
Kyle69-71 BBs
Make sure whatever dye you use is color fast. Seat belts get wet sometimes or yous clothing might....as me how I know
To seatbelt dye
