Trailing arm pocket
Old Jun 19, 2007 | 08:45 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Default Trailing arm pocket
I need some suggestions on cleaning up my trailing arm pockets before reinstalling the arms. They have some surface rust, and I want to make sure it doesn't become a problem in the future.
Old Jun 19, 2007 | 08:51 PM
SIXFOOTER's Avatar
SIXFOOTER
Use a brush with some Phosphoric etcher from HD, I use it full strength for 30 minutes or so, rince well, blow dry and paint
Old Jun 19, 2007 | 10:51 PM
72LS1Vette's Avatar
72LS1Vette
If the rust isn't bad you can sand off the loose rust and coat the pocket with either Rust Encapsulator, Rust Bullet or POR-15. Rust Encapsulator in a spray can might be the easiest way to go if you are just doing the pockets.
Rick B.
Old Jun 19, 2007 | 11:04 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
pics???
Old Jun 19, 2007 | 11:23 PM
Z-man's Avatar
Z-man
That's a tough job. Are you going back in with stainless parts where you can??
Old Jun 19, 2007 | 11:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Stainless is everywhere I could get parts - the shim/bolt kit and the parking brake kit.
Old Jun 20, 2007 | 08:30 AM
eastltd's Avatar
eastltd
Rick B.
You may want to consider a spot blaster to clean out the pocket properly before applying any paint. As you know, this area is prone to rust. If you're this far into it, you may want to be sure you have no serious rust issues.
Old Jun 20, 2007 | 08:32 AM
jgrigg's Avatar
jgrigg
Default What I did.
Just by chance I did this same thing last week. To the Passenger side anyway.
I used a wire brush the best I could, but it was sort of clumsy. I found that using my compresser and a blow gun tip removed all the dirt and very loose rust nicely.
After that I used a small piece of 60 grit sand paper to get what I could of what was left (not much). Sprayed the area with Metal Prep and then used POR-15.
I don't have any pics, but it didn't turn out too bad.
The idea I had after the fact was a small wire wheel on an extended shaft attached to a drill. Would have loved to try it, but didn't have the tool.
Hope this helps or at least gives you some ideas.
Jeff
Old Jun 20, 2007 | 09:35 AM
NHvette's Avatar
NHvette
All good suggestions and all would work well.
My choice is to use a Phosphoric treatment (Metal Ready/Stripkleen/Naval Jelly)
then coat it with POR-15 ... top coat with Krylon semiflat black.
Make sure all the seams are dry before coating ... a minute with propane torch helps.
Old Jun 20, 2007 | 10:30 AM
mikebaskette's Avatar
mikebaskette
Default Just finished
my second car. I use a Dremel tool with the cup and flat brushes. I buy the brushes on-line NOT from Dremel (to expensive) but cheap Asian crap that can be thrown away without crying the blues. Once clean I use Por-15 solvent with a tinning brush (for stiffness) and scrub good. Dry with paper towel until clean. Paint with Por-15, second coat one to two hours later. Let set for 24 hours. Wish I could post pix but I still don't get it.....how to post the pix. I don't top coat over the Por-15 due to the fact that dirt will wash off very easy from the surface. I sold Por-15 for ten years and have never found anything that can top this product.
Old Jun 20, 2007 | 10:42 AM
72LS1Vette's Avatar
72LS1Vette
I had a discussion about this with Dan at Van Steel a couple of years ago when I bought my trailing arms. He recommended a grade 8 bolt rather than a stainless for strength.
Rick B.
Old Jun 20, 2007 | 12:26 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The frame is solid - I've poked and prodded all over it with a heavy screwdriver. I just want to make sure it doesn't become a problem in the future, since I have things out of the way. The only rot in the car is the #4 reinforcements.
Old Jun 21, 2007 | 01:13 AM
SwedeAWACS's Avatar
SwedeAWACS
RE: Stainless bolt vs Grade 8 bolt
After working so hard to get the trailing arms out, I also had it in my noggin to go stainless everywhere. I had the same discussion as Rick B with Dan at Van Steel WRT the strength and ultimately I went with Van Steel's advice and used the Grade 8 bolts.
I did go with the stainless shims and stainless parking brake components though
Swede
Old Jun 21, 2007 | 08:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Rick B.
I got the stainless bolts with the stainless shims. I guess a quick order to Van Steel is in order...
Wasn't the stock bolt Grade 5?
Old Jun 21, 2007 | 10:13 AM
72LS1Vette's Avatar
72LS1Vette
Not sure. I beat on the bolts pretty hard trying to get the trailing arms off my 72 frame and they didn't mangle much at all. They were harder to cut also. Stainless shims would have been a nice OEM touch. A
couple of the original shims were so rusted to the bolt that I couldn't budge them with a crowbar.
Rick B.
To Trailing arm pocket
