Bad Spedometer
Old Jun 20, 2007 | 04:26 PM
CarlR's Avatar
CarlR
Default Bad Spedometer
My speedometer reads 70 when I'm actually going 65. Tires are the same size, everything else is original. Where should I start to look?
Thanks for any help,
Carl
Old Jun 20, 2007 | 04:38 PM
mdj21's Avatar
mdj21
what tires are you running on? are you sure that they are the exact same tire as what it came with back in 1979?
you will probably have to change the speedometer driven gear down in the transmission.
i had to change my driven gear becasue i was reading about 10 mph too high. it's a pretty easy job on a manual transmission. i suppose its probably easy on an auto trans also.
there are web sites with calculators to help you figure out which gear you need, but i am at work and do not remember any of them off of the top of my head. if nobody else helps out, i'll try to post a link when i get home.
hope this helps,
Mike.
Old Jun 20, 2007 | 05:16 PM
spedaleden's Avatar
spedaleden
hope this helps,
Mike.
Speed calculator
http://www.keislerauto.com/tools/gm_analyzer_5sp.html
Sorry that won't help you.
If you call Corvette Cental, Eklers, Paragon etc. They will sell you the right gear you need for the factory Trans. You need to tell them how far off you are in speed and they will sell you the right gear.
Old Jun 20, 2007 | 05:36 PM
CarlR's Avatar
CarlR
Tires are the same size as the original.
I'll note how much it's off, and the RPM's at highway speeds tonight.
One calculator said with 27.4" tires, 3.55 rear end, at 70MPH I should get about 3129 RPMS.
Old Jun 20, 2007 | 06:32 PM
Jc3vette's Avatar
Jc3vette
If your speedometer reads too high, a driven gear with one more tooth will slow it down approximately 5 MPH.
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old Jun 20, 2007 | 09:31 PM
mdj21's Avatar
mdj21
here are a couple of good links that helped me fix my fast speedo reading problem:
http://www.tciauto.com/Products/Tech...eedo_gears.asp
http://www.novaresource.org/speedo.htm
by the way, the large speedo gears are for the automatics and the small gears are for the manuals.
the AIM should tell you how many teeth you have on the drive gear inside the transmission.
good luck,
Mike.
To Bad Spedometer
