Hi
68-69 vented gas cap.
70-74 non vented gas cap.
74-82 ???? gas cap.
On 70 -74 non vented gas cap use becuase of the vapor system, but I prefferd the vented gas cap because if you have a good close fuel system it will prevent a vacuum in the gas tank.
Thanks, Avner
It depends on what you have for a fuel system. The stock fuel pump had a return line and an unvented fuel cap. I have an after market Holley without a fuel return line and I don't have a vapor canister, so I had to switch to a vented cap.
