vette engine
Old Jun 26, 2007 | 04:51 PM
jonathanjoe's Avatar
jonathanjoe
1st Gear
Default vette engine
i recently bought a 350 small block from a guy and he said that it could have possibly came out of a vette, how can i determine if it did?
Old Jun 26, 2007 | 07:51 PM
international blue's Avatar
international blue
I'm not sure why it matters. There is really no difference for most passenger car blocks. If you are planning to build for performance, you know the type of block you need and the casting numbers that you want. A 350 is worth the same weather or not it came out of a vette or not. Unless its dated and coded for someone who wants it. Than they will pay a little more.
All casting numbers and engine assembly suffix codes are searchable on the internet. If you have a Corvette, what dates and stampings are correct matters most.
What casting number and engine suffix code is it?
Old Jun 26, 2007 | 07:54 PM
69monzacpe's Avatar
69monzacpe
Depending on the 350 and year made, Corvette 350s had 4 bolt main bearing caps, so if you pull the oil pan, and it only has two bolts per main bearing cap, it probably didn't come from a vette.
Old Jun 26, 2007 | 08:19 PM
dannyman's Avatar
dannyman
Say what?? My original is a two bolt!! Yes, corvette!!!
Old Jun 26, 2007 | 08:34 PM
steve dalla's Avatar
steve dalla
L82=4 bolt
Old Jun 26, 2007 | 08:35 PM
Duke94's Avatar
Duke94
L-48's were 2 bolt, L-82's are 4 bolt. Both are used in Vettes.
Old Jun 26, 2007 | 09:28 PM
72LS1Vette's Avatar
72LS1Vette
If the block pad at the front of the pass. side head has what looks like a serial number and some other numbers it could be a Vette engine. Unless it's a high compression 427 or all-aluminum smallblock it's pretty much like any other Chevy 350. I hope you didn't overpay because it's a 'Corvette' engine.
Rick B.
Old Jun 27, 2007 | 09:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Numbers stamped on the pad at the front of the right head. You should find two stampings. Jot them down and post them here.
Old Jun 27, 2007 | 10:15 AM
gkz's Avatar
gkz
Don't Vettes have ram horn manifolds?
Old Jun 27, 2007 | 02:11 PM
Easy Mike's Avatar
Easy Mike
Some. Won't mean a thing if the manifolds are not on the block. Pad stamps are conclusive.
Old Jun 29, 2007 | 04:30 PM
69monzacpe's Avatar
69monzacpe
My '69 base 350/300HP is a 4 bolt bottom end. I guess they may have changed that in later years when they got wimpy!
To vette engine
