Sealing the birdcage
Old Jun 28, 2007 | 01:45 PM
spearC3's Avatar
spearC3
Default Sealing the birdcage
As a lot of C3 owners, I have a leak in the right side of the birdcage. It is where most birdcages leak (right in the bottom at the point where the bonding strip is located) . I can not afford $$$ to do a complete birdcage repair where I need to take the front clip out. I want to know if any of you out there have found a way to at least seal the hole. Maybe a rubber spray or other non invasive method. Help is appreciated.
Old Jun 28, 2007 | 02:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
3M automotive undercoating, big, tall rattle can. Looks a lot like the old original factory stuff after it dries.
Old Jun 28, 2007 | 07:08 PM
spearC3's Avatar
spearC3
Thanks Mike. I will give it a try this weekend. Do you know if the 3M undercoating has the skinny straw adapter so I can really get in good between the bird cage and the fender strip?
Old Jun 28, 2007 | 09:10 PM
MorpheusGPR's Avatar
MorpheusGPR
Any pics of the area you are doing this too?
Old Jun 28, 2007 | 10:24 PM
petronix's Avatar
petronix
Be careful with the undercoating stuff. It any water can get under it, it will rust much worse than not coating it at all.
Old Jun 29, 2007 | 10:09 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by spearC3
...Do you know if the 3M undercoating has the skinny straw adapter so I can really get in good between the bird cage and the fender strip?...
No straw, but I may have misunderstood what you want to do. I used the 3M on the cowl and the wiper arm trough and sealed those with a surface application. No more leak for me. I did not shoot the stuff between the bird cage and fiberglass.
Old Jun 29, 2007 | 03:26 PM
NHvette's Avatar
NHvette
I wouldn't use any asphalt materials. They dry/crack/ and dissolve with solvents.
I sealed mine with a polyurethane roof sealer ... rubbery and good for 30 years.
The one on the bottom ... Home Depot $4/tube.
Get some lacquer thinner for cleanup.
To Sealing the birdcage
