Does thing come out!!!!
Old Jul 2, 2007 | 11:29 AM
copter's Avatar
copter
Default Does thing come out!!!!
I'm talking about my windshield washer bottle.Man that thing is crammed in there.Also how in the world do you put in the underhood light bulb.It's got that shield around the top half and I can't get a bulb in there.
Old Jul 2, 2007 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Year?
Old Jul 2, 2007 | 12:16 PM
cosmicvette's Avatar
cosmicvette
Assuming you are referring to your 82CE that is listed in your profile, if it has that washer bag/bottle that is crammed down in the LHS fender behind the front wheel (like my '70) it is a pain to get to from the top, luckily on my '70 the egg crates side grills can be removed for easy access.
Old Jul 2, 2007 | 12:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If it's like the one on my 77, you'll never remove it with the braking system in place. I was able to get the bolts out of mine by touch, flip the bottle over, and replace the pump. Not really a fun job.
Old Jul 2, 2007 | 05:23 PM
Durango_Boy's Avatar
Durango_Boy
Booster and master will have to come out first. No way around that. Does it leak? Pump bad?
Old Jul 2, 2007 | 08:17 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Last year, at the end of the first summer with my 81, I went to the quick oil change place where I take my DDs for a final oil change before storage. They found the washer bottle empty (I never used it) and they tried to fill it. It leaked out as fast as they pumped the washer fluid in. I put it on the "someday, maybe fix" list and put a drip pan under it at the storage garage.
Old Jul 2, 2007 | 08:30 PM
VettePower's Avatar
VettePower
Mine is the same way. luckily I only drive the car in nice weather, so I have not had the need to use it. But it would be nice if it worked!!
Old Jul 2, 2007 | 10:23 PM
...Roger...'s Avatar
...Roger...
I think it will go out the bottom.Remove the splash shield and the vapor canister.Check it out.
Old Jul 2, 2007 | 10:29 PM
randommj's Avatar
randommj
on my 74 the light cover can come off, thats what i did, removed the metal pice, poped in the new bulb, and put the metal pice back on
Miles
Old Jul 2, 2007 | 10:35 PM
hwcoop's Avatar
hwcoop
That will probably work, otherwise you will need to do this
Old Jul 3, 2007 | 06:09 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Well, you might not NEED to do that, but there's too high a probability that's what it would lead to.
To Does thing come out!!!!
