1967 Engine codes
Old Jul 18, 2007 | 01:17 PM
Brewster Green's Avatar
Brewster Green
7th Gear
Default 1967 Engine codes
Hello, I am new the site and needing some help. Looking at a '67, block number is T0917IT. I realize it is a HD block but there are numbers that follow: T0917IT 6101472, I am not familiar with seeing the number after the IT. If anyone could point me in the right direction as to there meaning or better yet if someone knows what they mean. I would greatly appreciate it.
Thank you in advance
Steve
Old Jul 18, 2007 | 01:21 PM
71 Green 454's Avatar
71 Green 454
Steve
Steve,
You'll probably get quicker/better responses if you post in the "C1 & C2" section.
Old Jul 18, 2007 | 03:37 PM
Brewster Green
7th Gear
Thanks I did post there, I submitted here before I realized what I did.
Old Jul 19, 2007 | 09:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Looking at a '67, block number is T0917IT. I realize it is a HD block but there are numbers that follow: T0917IT 6101472, I am not familiar with seeing the number after the IT. If anyone could point me in the right direction as to there meaning or better yet if someone knows what they mean. I would greatly appreciate it.
Steve
T Tonawanda (NY) engine assembly plant. All Corvette big blocks were assembled at Tonawanda.
0917 Engine assembly date, September 17th
IT Engine suffix code for L-88
6101472 Should be the VIN sequence of the car this engine was originally installed in. I do not recognize 6101472.
C2 and NCRS folks should be able to help. An L-88 will light up eyes just about everywhere.
Old Jul 19, 2007 | 12:30 PM
RPOL68's Avatar
RPOL68
Go here for 1967 codes.
http://www.corvetteactioncenter.com/...1967/67id.html
Sept 1966 would be a good date for the 1472nd Corvette built for 1967.
Could that 6 an "S"
To 1967 Engine codes
