Does anyone remember these????
Old Jul 21, 2007 | 09:01 PM
  #41
KTKelly's Avatar
KTKelly
Speaking of small cars.....
This is what I had in 1963 when I was still in high school. Only problem was that two healthy guys could pick it up and move it around. Never knew where the dang thing would end up if it was left alone for any amount of time.
Know what this is?
The wheelbase was such that it would have all four wheels on a normal sidewalk. And I once did a three point turn inside of a parking space at the local drive in hamburger joint....
Old Jul 21, 2007 | 09:05 PM
  #42
windup's Avatar
windup
This is what I had in 1963 when I was still in high school. Only problem was that two healthy guys could pick it up and move it around. Never know ehre the dang thing would end up if it was left alone for any amount of time.
Know what this is?
Fiat Topolino?
Old Jul 21, 2007 | 09:10 PM
  #43
KTKelly's Avatar
KTKelly
Nope......
Think motorscooter with four wheels...
When it needed tires, I bought replacements from Sear's. They were called "high speed wheelbarrow tires"...
It could hold two guys and two cases of beer. Unless the top was down, and then it could hold three people....
2 cylinder, 2 cycle. Top speed was about 45 unless you were going downhill....
Old Jul 21, 2007 | 09:11 PM
  #44
Vet76te's Avatar
Vet76te
Know what this is?
The wheelbase was such that it would have all four wheels on a normal sidewalk. And I once did a three point turn inside of a parking space at the local drive in hamburger joint....[/QUOTE]
I know it is a Fiat,..but for some reason I thought it was called a Jooey. Perhaps Jolly was just a nickname or something.
I had a Fiat 600 which looked much similar to that.
Old Jul 21, 2007 | 09:28 PM
  #45
KTKelly's Avatar
KTKelly
Nope.
It's definitely NOT a Fiat.
Actually, it's a 1960 Vespa 400
I painted mine a dark blue with a white racing stripe.......... Yeah a racing stripe on a car that would just barely do the speed limt....
Old Jul 21, 2007 | 09:58 PM
  #46
Vet76te's Avatar
Vet76te
A VESPA!!! I was thinking Simca, Renault, Fiat,...etc. I never dreamed it was a VESPA.
Old Jul 21, 2007 | 11:16 PM
  #47
KTKelly's Avatar
KTKelly
The great thing about driving that little car while in high school?
ALL the girls thought it was so cute.... It was the proverbial chick magnet...
Old Jul 22, 2007 | 12:32 AM
  #48
lowbuck72's Avatar
lowbuck72
Here's a couple of other oldies but goodies I owned in a previous life
Old Jul 22, 2007 | 07:05 AM
  #49
windup's Avatar
windup
This one is easy Triumph Herald/Vitesse
1360 or 2 liter?
Same as the vettes seperate body -chassis.
Old Jul 22, 2007 | 09:00 AM
  #50
Vet76te's Avatar
Vet76te
While we're at this,...did you know that the Triumph Spitfire uses the same shocks as the Corvette? (And I bet the Herald does too). It is true . If you buy a set of shocks that comem in a box with the model application written on the side, you will see That they BOTH use the same shock. Also, the Spitfire had the saem type independent rear suspension, seperate frame.
