V6 ??
Old Jul 20, 2007 | 10:00 PM
  #41
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Here's a little more 'real world' comparison:
We own two F-bodies, one is a LS1 and the other is a V6 (both '99). I'm getting roughly 250 miles with a tank (14gal) with the LS1 and 280 miles with the V6, both city driving with auto trans .... 18mpg and 20mpg ... not worth giving up two cylinders imo.... on the highway the LS1 is good for 24mpg (70mph on cruise control). The V6 simply sux...
Old Jul 21, 2007 | 12:09 AM
  #42
FRSTR90's Avatar
FRSTR90
Originally Posted by 63mako
You want some gas mileage and performance 3 2 bbls. I got 20 MPG with the old setup with a 4 speed and 3.55 gears and it would roast 295's for an 1/8 mile. You run on a 2 bbl untill you kick it. With an overdrive trans I could see 23 or 24 pretty easy.
What cam where ya running?
Old Jul 21, 2007 | 12:29 AM
  #43
63mako's Avatar
63mako
St. Jude Donor '08-'09
327, 186 ported heads, Hooker headers, 10 to 1 comp. 350 HP GM hydraulic cam "151" Nice, low maintainance streetable setup. The mileage will drop in a hurry if you kick in the outboard carbs though.
Old Jul 21, 2007 | 02:17 AM
  #44
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by lowbuck72
You know, GM built a lame V8 back in the 70's which displaced about the same as a six. It was a 262 cu in small block. With a decent set of heads and a 2 barrel, it could be pretty efficient and still looked the part when you opened the hood. With an overdrive transmission and not-too-wide tires, you could have the closest thing to an economy Vette. (But it still would not get as good a mileage as a stock C5)
During the same time period you could get a 292 I6 in a truck...
Old Jul 21, 2007 | 03:05 AM
  #45
enkeivette's Avatar
enkeivette
It also depends on the kind of driving that you will be doing. I will get around 8mpg with my stroker engine in the city, but on the highway in 6th gear I'm getting 20+mpg. So if you're only driving this car in the city, an OD will make little to no difference. But on the highway, it could make all the difference.
Old Jul 22, 2007 | 12:43 AM
  #46
lowbuck72's Avatar
lowbuck72
I have a'68 Chevy Van I've had for 25+ years. It originally had a 230 cu in in line six and a three on the tree. I could get over 20 mpg in normal driving. About 8 or 9 years ago I built a 350 cu in small block with cam, some porting, intake, headers, etc., and now I just can't get real good gas mileage. I can't figure out why...
Old Jul 22, 2007 | 01:44 AM
  #47
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'm building a PFI 250 with a rather lumpy cam and flat-top pistons for my '54 GMC panel truck...with an NV4500 behind it, it should move down the highway quite nicely.
