power window assembly guide
Old Jul 19, 2007 | 06:06 PM
bowser22's Avatar
bowser22
8th Gear
Default power window assembly guide
Hey,i own a 77 corvette with power windows,im currently in a pile of **** as to how to install a new power window gear.Im looking for a complete guide on removal and installation and/or an assembly diagram
"bowser
Old Jul 19, 2007 | 09:58 PM
dobroman2001's Avatar
dobroman2001
"bowser
Do you mean power window motor when you say "power window gear" ?
If so, on my '76 there is a thin plate that covers the motor that can be seen after the door panel is removed. Once that plate is removed, the motor can be seen. If the window is in the "up" position then you are in luck!! If it is down the it becomes harder. My windows were stuck in the up position so I was able to remove the 3 bolts holding the motor in place. Once those 3 bolts are removed the motor will come out with a little turning and twisting...etc. I also bought rebuild motors from Advanced Auto for $35.00 per motor.
I think the Installation Guide will tell you to remove the Regulator which is a "REAL" task!
Old Jul 20, 2007 | 10:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
One of the Corvette magazines (can't recall wich) did a How-To article on rebuilding power windows. Check Vette and Corvette Fever.
To power window assembly guide
