Help with engine codes please
Old Jul 19, 2007 | 08:28 PM
nealkeith's Avatar
nealkeith
Default Help with engine codes please
My 1969 vette has vin#194379S723922 ENGINE BLOCK CASTING#3970010 STAMPED#19J111055 CASTING DATE H118 according to Chevrolet by the numbers book this engine was not manufactured until april of 1969 but casting date says August 11,1968. Anybody know anything about this?
Old Jul 19, 2007 | 09:25 PM
stingr69's Avatar
stingr69
You posted everything BUT the assembly date/suffix stamp. I suspect it was an engine out of a full sized passenger car assembled at the Janesville WI plant. The most likely reason you have an "8" (if it truly is an "8") is block was cast in 1978 for a 1979 model year vehicle. I bet you have a 3 digit suffix stamped on the pad and that would clinch it for me.
An early production engine for a 1979 full sized passenger vehicle is my guess.
-Mark.
Old Jul 19, 2007 | 10:28 PM
nealkeith's Avatar
nealkeith
The book Chevy by the numbers said that this block casting number ran until 1975, and was only built as a four bolt main engine, 300 or 350 hp. Also no suffix, above this number on the left is "10" on the right is "RH" which I took to mean Right hand rotation.
Old Jul 19, 2007 | 11:11 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
That book you refer to is only 1970-75 Numbers .... this particular engine block was produced 1969-1979 as a 2 or 4 bolt, 165 to 370hp.
*Information from Corvette by the Numbers, 1955-82, Alan Colvin
Old Jul 20, 2007 | 08:27 AM
ghoastrider1's Avatar
ghoastrider1
casting dates and build dates will not match, ever. The blocks sit awhile, till needed for a certian car. Build dates are then stamped. My block has the same "cast" code as yours (3970010) . These blocks were as follows..350, 1969 thru 1980,2 or 4 bolt mains.
327, 1969, 2 bolt, truck industrail
302, 1969, 4 bolt, Z-28 camaro
Also, these blocks are the "high nickle content" blocks, which are the strongest blocks made in the era. drag racers like them. My info comes from http://www.mortec.com/
Old Jul 20, 2007 | 08:31 AM
corvetteload's Avatar
corvetteload
-Mark.
If cast in the 70's, the year date would be 2 digit, not a single digit like in the 60's................
Old Jul 20, 2007 | 09:09 AM
ROBMERRILL's Avatar
ROBMERRILL
Approximate birthday 194379S723922: July 8, 1969
1969 Engine Block Casting Numbers:
Casting # Cubic Inches Description/Application
3932386 350 300 & 350 Horsepower (early)
3932388 350 (unverified)
3956618 350 300 & 350 Horsepower (mid)
3970010 350 300 & 350 Horsepower (late)
3935439 427 390, 400, 430 & 435 Horsepower (early)
3955270 427 390, 400, 430 & 435 Horsepower (early)
3963512 427 390, 400, 430 & 435 Horsepower (late)
3946052 427 430 Horsepower ZL1 (aluminum)
Your VIN Report:
Division (1): Chevrolet
Car Line (9437): Corvette Sport Coupe
Model Year (9): 1969
Plant (S): St. Louis, MO
Sequence Number: 723922
Old Jul 20, 2007 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Someone has swapped engines in your '69.
Sorry.
Old Jul 20, 2007 | 10:30 AM
nealkeith's Avatar
nealkeith
I didn't buy the car as numbers matching, I'm just trying to find out what the engine actually is.
Old Jul 20, 2007 | 01:31 PM
ghoastrider1
I had to strip mine down to find out. Best thing about it was that it came with a set of 461 heads off of a 65 something or another.
Old Jul 20, 2007 | 02:21 PM
Easy Mike's Avatar
Easy Mike
The Janesville, WI assembly plant now makes Suburbans and Tahoes. Not sure what was in production at Janesville in 1969. I'm guessing you've got a 350 out of a Caprice.
There should be a second number on the engine pad in addition to the VIN derivative stamp. It will list the engine suffix code and identify what you have.
Old Jul 20, 2007 | 05:02 PM
nealkeith's Avatar
nealkeith
Default Found Engine Codes!
T0825DRH, maybe a truck engine?
Old Jul 20, 2007 | 05:35 PM
ghoastrider1
you guys are good.!
Old Jul 20, 2007 | 07:17 PM
nealkeith's Avatar
nealkeith
Default Thanks Guys
Thanks Guys, at least I know what it is.
To Help with engine codes please
