Body bushings
Any advice would be greatly appreciated.
I'm in the process of doing this right now. Not really that bad of a job once you get everything so you can lift the body.
If you're doing it yourself the advice I received, since I'm not doing a full body off, was Lift one side at a time. Just enough to do the work you need to do. I invested in a good set of Energy suspension body bushings. They fit great. I used my engine crane and a very solid rachet strap to lift the body. I got the strap from H.D. I think it was 15 or 20 dollars.
Make sure you have an extra helping hand around because there are a few things that you just can't do yourself. I have my 11 year old son and my twin 16 yr old daughters to help me. We have the P.S done and plan on doing the D.S this saturday. I've already removed the bushings on the D.S but I'll try to get some pictures of the process if you'd like to see some.
Unless they're in pristine condition replace the #4 reinforcements while you're at it. You don't want to have to go through this all again a few years down the road. Mine were rusted out so it was a no brainer for me.
Do a search in this forum on Body Mount Replacement. I did and found quite a bit of very helpful information and advice including a list of items that you'll have to remove to lift the body.
My car is almost entirely disassembled so I didn't really need the list but it was nice to have so I could check to be sure there wasn't anything I missed.
Be sure to use a strap on the front clip when you're lifting the body. It needs to be supported.
When removing the old body mount bolts use lots of PB blaster. I managed to get the old bolts out of 2 and 3 without breaking them. If you happen to break them, you'll have to pull the body off to replace them (I've read there's no other way)
Feel free to PM me with any questions you may have or just post.
I hope this helps and good luck with your project.
totally. I don't even have a #4 body mount. It's completely gone. Rusted to nothing. I'm waiting till winter, though, because I'm afraid of what else I'll get sucked into.
My ashtray got full and now I am midway thru a $12,000 body off restomod
couldn't resist, actually I nicked a palm tree when the brake pedal pin fell out which pretty much trashed my left front fender, bumper cover, fender skirt, yadda, yadda.....
BUT, when I get done, it SHOULD be a very cool car.
