7-leaf vs. 9 leaf
Old Jul 24, 2007 | 05:53 AM
Bric's Avatar
Bric
Default 7-leaf vs. 9 leaf
Ready to order my spring and was wondering what the differences between the 2 are.....
If I read correctly the 7 leaf is rated at 360lbs. and the 9 leaf 330lbs. I have a chance to pick up a 7 leaf at a very good price and was wondering what difference it would make in my 76 over the stock 9 leaf and if I would have to compensate for it elsewhere on the car?? Thanks for looking!
Bri
Old Jul 24, 2007 | 05:53 PM
Lightweight 001's Avatar
Lightweight 001
The factory spring rate for a 9-leaf is 196 lbs. and a 7-leaf is 330lbs. You must consider that your original spring as lost somewhere around 15% of its original spring rate so just replacing it will stiffen up the rear. For a daily driver I would suggest going back with a 9-leaf, if your looking to road race your car you will need something stiffer. On my car I bought two 9-leafs and mixed and matched leafs until I found what I liked. How much did you find the 9-leaf for?
Old Jul 24, 2007 | 06:03 PM
Bric's Avatar
Bric
The 9 leaf was $120 from a site vendor. The 7 was from a local guy and under $100 new. I was just wondering if I used the 7 leaf if I would have to adjust anything elsewhere on the car i.e. heavier front springs.
Thanks for the reply!
Bri
Old Jul 24, 2007 | 06:09 PM
427-390's Avatar
427-390
Bri
If you go with the 7 leaf, you are going to be experience a kidney rattlin' ride my friend. Those springs were originally ordered with the F-41 race suspension and are designed for hard cornering and acceleration. Most suspension vendors even note when ordering a 7 leaf spring that unless your car came with it originally, or has the F-41 suspension, they recommend you not order it.
Old Jul 24, 2007 | 06:20 PM
weimer20's Avatar
weimer20
Bri
If you go with the 7 leaf, you will want to change out the front springs as well to match. If you leave stock in front, you will get some adverse handling characteristics due to the imbalanced spring rates. I personally don't think that the 7 leaf is really all that bad. I prefer it. It's just a matter of opinion I guess and what the car is "built" for. Just my humble opinion.
Old Jul 24, 2007 | 07:00 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I'd seriously consider a composite monospring.
Old Jul 24, 2007 | 07:04 PM
Belgian1979vette's Avatar
Belgian1979vette
My car originally had a 9 leaf. I put in a 7 leaf because the car went down in the back to much on acceleration. There simply wasn't enough pressure on the front any more to get good cornering.
Old Jul 24, 2007 | 07:40 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I'd use at least the 7 leaf!
JIM
Old Jul 24, 2007 | 07:41 PM
vettecrazy88's Avatar
vettecrazy88
Just put 7 leaf on my 75 that I have a big block in so I definitely had to change front springs too.
Ride is stiffer, but you feel the road better and it doesnt roll as much. Not so stiff to break up kidney stones.
I would do it again.
Old Jul 24, 2007 | 07:45 PM
guitarcrazy02's Avatar
guitarcrazy02
If you want a stiffer, better handling spring... http://www.vbandp.com/detail.aspx?ID=550
Softer, better ride...
http://www.vbandp.com/detail.aspx?ID=538
It's a bit more than a 7 or 9, but rides much better, responds quicker, and lasts much much longer
Old Jul 24, 2007 | 10:11 PM
gccch's Avatar
gccch
A related question...
Why do so many restored corvettes look like they are jacked up in the rear? Is this improper leaf spring adjustment or the wrong spring? To me this totally ruins the look of the car.
Old Jul 24, 2007 | 10:12 PM
Bric's Avatar
Bric
Thanks for the replies guys!
I had originally planned on using the 7-leaf rear spring, a set of Moog 474lbs/in front coils, the stock front sway bar, and a 4 pack of KYB GR-2's. Anybody have an idea if that would be an OK setup?
I am almost done removing the majority of rear-end components of my 76. Just the differential cover is left, all else is out. Alot of the items I removed and expected to replace turned out to be in 'really decent' shape and will be able to save some money. Hmmmmm....maybe a poly spring will be in my future.
Thanks again!
Bri
Old Jul 24, 2007 | 11:25 PM
Sharkboy's Avatar
Sharkboy
My thoughts exactly! Is this situation able to be corrected with the longer spring bolts or does a new spring have to "settle"?
Old Jul 24, 2007 | 11:32 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Jul 25, 2007 | 12:02 AM
Tom73's Avatar
Tom73
The way that I understand it is that a "correct" rear spring is almost impossable to find. Most are too stiff, have the wrong arch, have the worng compression, etc, etc, etc. Best bet is to find a good used spring if you want original or just go with a composit spring if originality does not matter.
Old Jul 25, 2007 | 12:10 AM
FRSTR90's Avatar
FRSTR90
Thanks again!
Bri
I'd go with the 550lb front springs just because you going with the "HD" or "Heavy Duty" rear spring! Chevrolet designed them to be mated together might as well leave it...
However, I don't think that the new 7 leafs are as strong as the originals... I have got a replacement 7 and my dad has his original 7 with new rubber bushings and his spring has no give where as mine rides pretty comfy...
Old Jul 25, 2007 | 12:13 AM
FRSTR90's Avatar
FRSTR90
The ride height of the rear is totally adjustable... You have to long bolts that go from the trailing arm down to the spring and you tighten the lock nut on each side until you are satisfied on how the car sits.
To 7-leaf vs. 9 leaf
Old Jul 26, 2007 | 08:43 AM
Ganey's Avatar
Ganey
Exactly. The front springs are 550 for the 7 leaf rear.
The FE-7 has 550 front, 7 leaf rear, larger ft. sway bar & adds a rear bar. Great for performance.
Old Jul 26, 2007 | 09:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by FRSTR90
...The ride height of the rear is totally adjustable....
Rear ride height can be dialed in with the spring bolt nuts.
Old Jul 26, 2007 | 10:06 AM
SmokinBBC's Avatar
SmokinBBC
I have a BB and had a SB. I have used both steel and composite for street driving. I have no experience in track driving.
My recommendation is the VBP 360 rear combined with their 550 fronts. The 550's will lower the front of your vette by about an inch because of the way that they are made. Get the longer rear bolts so that you can adjust the rear. Remember to keep your halfshafts approximately parrallel to the ground.
Combine this with a good set of performance shocks like Bilsteins.
Just my .02. Whatever you do, enjoy your ride!
