clocks
Old Jul 29, 2007 | 08:24 AM
babylonvette's Avatar
babylonvette
Default clocks
i am putting the dash back in my 72 project car and was wondering if i should go for the quartz clock being the original is not working and don't know how long a regular clock lasts and a quartz is lifetime
Old Jul 29, 2007 | 08:44 AM
Deron's Avatar
Deron
I just put a new clock in my 73, It's working and i'm praying cause I knew I should have went for the upgrade. I check it everymorning to see if its still working
Old Jul 29, 2007 | 09:18 AM
Localbulldog's Avatar
Localbulldog
I did a search for clock repair and found a closed thread with a paper detailing the cleaning and repair of the clock. Sure enough after following the instructions the clock started working !
A very satisfiying project.
The thread is called "File Your Points To Fix Your Clock"
Old Jul 29, 2007 | 08:05 PM
babylonvette
thanks for the replies maybe i'll take a look maybe i can save some money as it works sometimes if i tap it thanks artie
Old Jul 29, 2007 | 08:52 PM
DARROW's Avatar
DARROW
Clock"
Could not find this post help ( this would be a good stickey))
Old Jul 29, 2007 | 08:53 PM
Green73's Avatar
Green73
I cleaned up my clock, probably with the same paper the earlier post was taking about. Haven't had any problems since. Clean it up and see if it works.. it's not that hard to get back out.
Old Jul 29, 2007 | 08:55 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I bought and installed a quartz clock while my dash was out. It works and keeps perfect time. I still have the original and am going to try the repair procedure when time permits...The quartz is as good as a timex however...
Old Jul 30, 2007 | 07:05 AM
Localbulldog
Babylonvette - The paper is a closed thread. I'm not sure how to post it but I can email you the page with your email address or hopefully someone more knowlege can help us out.
Its a great explanation as to how to fix the clock.
Old Jul 30, 2007 | 08:10 AM
Ganey's Avatar
Ganey
Contact cleaner to clean out & clock oil may get it going.
Mine has always kept excellent time & was working fine when removed.
The clock adjusts speed when it is set forward (faster) or backwards (slower). It may take several settings for it to be right. Only needed to be set for daylight saving time.
Localbulldog
You can post the link (in address bar of the topic).
Old Jul 30, 2007 | 09:20 AM
Wuttin's Avatar
Wuttin
More satisfying than most projects I've done. I smile every time I look down and see the second hand moving. Give it a try and default to the quartz if you can't get it going. The real key was to use the contact cleaner to strip all of the old crud from the works. The mechanism is so light that even a slight build-up over the years binds it up.
Old Jul 30, 2007 | 11:02 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I replaced my clock with a quartz unit. You cannot tell the difference by looking at it and it keeps accurate time. Good luck with your decision.
Old Jul 30, 2007 | 12:56 PM
VCuomo's Avatar
VCuomo
If you've got an NCRS award winner (or candidate), then get the original clock repaired (and yes you can tell by looking at the clock if it's quartz or original because the seconds hand moves differently, and you won't get the periodic spring winding noise).
But, if you don't care about NCRS points and don't mind spending the $, then why would you stay with a clock that doesn't keep time very well and is prone to mechanical failure? Keep the original, but replace it with a quartz clock.
Old Jul 30, 2007 | 06:19 PM
Localbulldog
Wuttin - Your Right -- that rewinding click had me wondering what that strange noise was ..................until I saw that second hand moving around
Old Aug 5, 2007 | 08:46 AM
Localbulldog
Did you guys get the pm I sent with the thread for the clock repair ??
Old Aug 5, 2007 | 09:58 AM
stingr69's Avatar
stingr69
The thing that kills the original clocks (other than time and crud) is running out of electricity. If you keep using the car regularly so the battery stays charged OR hook up a battery tender the clock will live a lot longer. Disconnecting the battery or letting it run down is what hurts the points on the clock.
-Mark.
Old Aug 5, 2007 | 07:08 PM
C3 4ME's Avatar
C3 4ME
Localbulldog, could you please send that to me also, thanks!
Old Aug 5, 2007 | 08:58 PM
RMS73's Avatar
RMS73
Try this:
http://members.aol.com/jjneyjr/clock/grepair2.htm
Roger
Old Aug 5, 2007 | 11:33 PM
7T1vette's Avatar
7T1vette
The most common [and most serious] reason for the original electro-mechanical clock to fail is that the contact point for the rewind solenoid fatigues through so that the points don't make contact any more. The original design is really neat...it's a regular mechanical clock with mainspring, etc. which also has a rewinding solenoid in it (rewinds about every two minutes). You can buy a rebuilding kit for the original design clock from ZIP Products for around $75. It includes some new gear pieces and a new main body; you put the new stuff in your old clock housing and dialface. I did it and haven't had a problem in the last 2 years. Obviously, the quartz movement is the most reliable thing to do. (But the second hand won't move like the original!!!)
To clocks
