Steering Column Painting
Old Jul 29, 2007 | 03:34 PM
79vetter's Avatar
79vetter
Default Steering Column Painting
I took a mouse sander to knock off all of the old paint.
What would be the best Primer to use on these surfaces? Is it just a plastic - thus plastic primer?
Also, I was planning on using my leftover Interior Dye for the final coat.
Any opinions on this?
thanks
Old Jul 29, 2007 | 03:40 PM
Deron's Avatar
Deron
Mine was metal so idon't know if you need the primer (I would assume you should). After light sanding mine, I cleaned it up real good with lacquer thinner and used the ecklers interior dye. It looks great and it's held up well.
Old Jul 29, 2007 | 05:27 PM
Le shark81's Avatar
Le shark81
If you want paint to stick on plastic, you've got to use plastic primer IMHO
Old Jul 29, 2007 | 06:01 PM
ffas23's Avatar
ffas23
I wouldn't use paint thinner on plastic. Its ok on metal but not on plastic. It will eat into it. I use rubbing alcohol to clean the surface once done sanding. I painted the column in my Street Rod using a black chip guard paint recommended to me by a body shop years ago. I had to mix it up and spray it though my spray gun. Be careful using a sander on your steering column. All you really needed to do was to get yourself some wet sanding paper. I usually start off with 400 grit wet with a bucket of water and sand it down smooth. Prime all bare metal. A steering column wouldn't take very long to do.
To Steering Column Painting
