74' wheel options
Old Jul 30, 2007 | 05:37 AM
sm66p's Avatar
sm66p
8th Gear
Default 74' wheel options
Does anyone have a good photo from a 74' showing OEM wheels ?
Were several types available ? What was the basic color?
Any info or pics will be helpful .
Any suggestions where to by replacements?
thank you
Old Jul 30, 2007 | 05:51 AM
curtis74's Avatar
curtis74
Well of course the 1974 Corvette had a standard 15 inch wheel with 5 x 4.75 bolt pattern and a 4in backspacing. 8" wide slotted steel wheel. They all came standard with the rally type wheel. It doesn’t appear there was another option for wheels, but you could get two different types of tires however. RPO QRM White stripe nylon steel-belted radial tires GR70 x 15 ($32). RPO QRZ GR70 x 15 raised-white-letter steel-belted radial tires ($45). These wheels were of course steel with a chrome rig and chrome center cap.
Ecklers has a 4 wheels set you could get.
http://www.ecklers.com/product.asp?p...3&dept_id=1419
Old Jul 30, 2007 | 06:29 AM
Bob Onit's Avatar
Bob Onit
The color on the steel Rallye wheels is Argent Silver.
I have read that Cast aluminum wheels were offered (in '73 at least) but I don't know if any ever made it to the end consumer. I don't recall the specific reasons.
Hope this helps.
Old Jul 30, 2007 | 10:05 AM
dmaaero's Avatar
dmaaero
I read that cast alum. wheels were offered in 74 also but no one didn"t order them and none were sold ! Doesen"t surprise me, my original owner didn"t even splurge for the passenger door mirrow option
Here"s the original ralleys on my 74 someone had painted them black
Old Jul 30, 2007 | 11:37 AM
ffas23's Avatar
ffas23
I don't think there ever was a passenger door mirror option on a '74 Corvette or any of the earlier Corvettes until they started using the painted mirror housings on the later year C-3's
Old Jul 30, 2007 | 11:44 AM
Bob Onit's Avatar
Bob Onit
Who knows
According to this sheet
http://www.corvetteforum.net/c3/vette73/S_OPTIONS.htm
the mirror was an option (extra cost item) in '73 but they also list the shoulder belts optional for verts only.
I have read that of all 73's (both coupes and verts) only 777 were equipped with the shoulder belts
Old Jul 30, 2007 | 12:39 PM
ffas23's Avatar
ffas23
Originally Posted by Bob Onit
Who knows
Wow that is something I never knew. Driving these cars since '71 I never remember seeing one of these earlier Vette's back then with a passenger door mirror. I saw later on when someone would put one on that side though. I see plenty today for sure but I still have only one on the driver side as came from the factory on mine.
My car must be one of the 777 since my Coupe has shoulder belts.
Old Jul 30, 2007 | 01:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Optional aluminum wheels (big wheels) were to have been introduced for the 1973 model year. They did not make production and were recalled due to porosity problems. None were sold to the public in 1973. The big wheels eventually showed up for the 1976 model year.
All 74s and 75s had ralley wheels (73s too, for that matter) since there was no optional wheel available.
Old Jul 30, 2007 | 02:36 PM
ffas23's Avatar
ffas23
Here's a picture of my '73 Coupe with a set of '82 Corvette Wheels and Tires. Back in late '82 I purchase the whole set from a fellow who didn't want them on his new 1982 Corvette at the time. He wanted a wire type of aftermarket wheel instead so he sold me all 4 wheels, lugs nuts and tires back then for around $650 if I remember correctly. They were just taken off the car as new as they came from the factory. As you can see in the pictures they are still on my car since this is a recent digital picture taken being I don't drive the car much as it only has 25k miles on it. When I purchased this car from a friend of mine the original owner back in early '82 the car only had a little over 17k miles on the odometer.
Old Jul 30, 2007 | 03:42 PM
7t5's Avatar
7t5
St. Jude Donor '14
I highly recommend that you buy a corvette black book. All of this info and more is in there and the book is less than $20. In fact, I would guess most of the info in the replies to your post was found in the black book!
I have one and use it all the time.
Old Jul 30, 2007 | 04:31 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Right side mirrors were a dealer installed option on all 1968 to 1976 Corvettes. In 1977 the new sport mirrors were offered as a factory option. Also some early 1974 Corvettes you could get the PO2 hub caps.
Old Jul 30, 2007 | 10:13 PM
sm66p's Avatar
sm66p
8th Gear
Thanx for all the input. Now bear with me here , ( new to vettes)
what is a black book and do you find one ? Thank you again.
Old Jul 30, 2007 | 10:16 PM
Bob Onit's Avatar
Bob Onit
By Mike Antonick
Avail at Amazon and many other places.
Old Jul 30, 2007 | 10:41 PM
Green73's Avatar
Green73
I picked up my "set" of rally’s at a show last year. The wheels are repo, powder coated gray/silver, Chinese trim rings and vintage caps. By far one of the most economical ways to have the stock look. I liked the fact that the wheels were brand new, and therefore I didn't have to worry about if a vintage, date coded steel wheel had been bent in the last 35 years. Powder coating is great and I don't have to worry about rust. The foreign trim rings have a clip all the way around, are cheap and look great. The vintage center caps are easy to clean up. I hit mine with some spray paint for the black recesses and am very happy with the results. Good Luck.
Old Jul 30, 2007 | 10:59 PM
Bob Onit's Avatar
Bob Onit
I have one after market ring on my car and the inside lip is razor sharp..... I found this out the hard way the first time I washed the rim.
Actually could have used a few stitches....
Old Jul 30, 2007 | 11:40 PM
Green73's Avatar
Green73
Interesting... the rings I have do not have that issue...
Old Jul 31, 2007 | 07:05 PM
WhoDidTheElf's Avatar
WhoDidTheElf
2nd Gear
Hey guys, new to the forums!
Anyways, I had a question that was regarding wheels too. I didn't want to make a new thread, and spam the place up so here it is.
I have a 68 with stock rims on it right now and wanted to put 17x9 1/2" on it, or the back at least. Problem is I don't really know what back spacing to use. I've been told 5 1/2" (by two places now) but I know that's wayyyyyy to far. The rims right now have 275/50 tires on them (way to big I know :/ ) and there is a 1/4" spacer back there, witch should make the total backspacing 4 3/4". Now would that back spacing be fine for the new rims considering the tire that's going to go on them will be the same width?
Thanks in advance! And sorry if I hi-jack the thread.
To 74' wheel options
Old Jul 31, 2007 | 07:44 PM
RunningMan373's Avatar
RunningMan373
Who knows
If that's true, I got one of them. I think the Pass side miror was a dealer only installed option,.
Old Aug 1, 2007 | 09:12 PM
1973yj8owner's Avatar
1973yj8owner
Default 1973 yj8 wheels
Hope this helps.
I own a set of 1973 yj8 wheels part number 329381. The mirror was dealer installed in 1973. I have one on my car.
Old Aug 1, 2007 | 09:19 PM
1973yj8owner
Default 1973 yj8's
I have a set of 1973 yj8's. They were purchased at a Chevrolet Dealer's parts department in suburban Philadelphia. The manufacture dates cast on the reverse side of each wheel are October 1972. The part number 329381 and the letters xm are also cast in the reverse side of each wheel. I have one of the original shipping boxes. It has a stamp shipped from American Racing to GM and the GM part number 329381.
