Rear filler panel Question
Old Jul 30, 2007 | 12:37 PM
jcswm's Avatar
jcswm
Default Rear filler panel Question
I tried the paint/body forum first with no luck so I'm posting my question here.....
I put sidepipes on my '73
I'd like to install the rear filler panel to fill the factory exhaust holes
The filler panel is bolted in place from the factory.
If I Glass it in place to get rid of the ugly seams will I have to cut it or remove it in the future if I decide to remove the body from the frame in the future???
Old Jul 30, 2007 | 01:35 PM
pws69's Avatar
pws69
Yes
Old Jul 30, 2007 | 01:41 PM
RPOL68's Avatar
RPOL68
Eclkers makes a rear filler panel for corvettes retrofitted with side pipes. They bolt in and cover the old exhaust opening. If you use this panel you will have a line there. I believe the true 1969 factory units were fiberglassed over.
That panel you are showing is the retrofit panel from Ecklers #10239.
Old Jul 30, 2007 | 01:47 PM
SuprJames's Avatar
SuprJames
No. I've removed my body with the filler panel bolted into place. I'm taking it off here in a couple weeks with it glassed in so I hope I'm right!
Old Jul 30, 2007 | 02:12 PM
BB72's Avatar
BB72
I bought one of those from Corvette America. I'm actually going to have to cut it in half and add a half inch to it...piece of crap
Old Jul 30, 2007 | 02:22 PM
pws69's Avatar
pws69
WHY - did you widen the rear end?
If you did not, then you shouldn't have to do anything to it but bolt it in. When I put mine in, it was also "short" by about that much - but that's normal (and well documented)! When you bolt it in, it will pull (stretch, if you will) the panel to the right size and as that happens, the various curves in the panel will fall into the correct places.
My observation after having installed one - I don't think it's a "piece of crap" at all (I have a couple I could show you that ARE) - it's actually a nice piece that fits well and looks good.
Old Jul 30, 2007 | 02:31 PM
SuprJames's Avatar
SuprJames
Same here.
Old Jul 30, 2007 | 05:25 PM
Alan 71's Avatar
Alan 71
In 1969 the rear valance panel for side exhaust cars had a straight seam on each side where it meets the quarter panel. The quarter panel was different too, in that it had a straight edge where it meets the valance panel. Each side was joined by 2 bolts. The valance was installed after the body was dropped on the chassis. The body needs to be tilted to quite a sharp angle to clear the rear cross member if the valance is permanently installed.
I think the straight seams look good if the body work that needs to be done on each quarter panel is well done.
Regards,
Alan
Old Jul 30, 2007 | 06:39 PM
BB72's Avatar
BB72
Well, the two raised vertical portions of the panel that the bumper supports go through are about a half inch too narrow. Plus one of the two upper pieces(where the two bolts go through) that fit into the upper body was cut wrong. It's not worth my time to send it back. Keep in mind this is a hand laid piece . Not press molded.
Old Jul 31, 2007 | 09:43 AM
SuprJames's Avatar
SuprJames
I'll post pics when I pull my body off here in about three or four weeks.
Old Jul 31, 2007 | 10:04 AM
71rdster's Avatar
71rdster
I got the aftermarket piece from Eckler's. Fits perfect.
Old Jul 31, 2007 | 02:27 PM
gator79's Avatar
gator79
looks like you neeed flares you can get the body off with it in place you just have to tip the body to the rear for it to clear the rear frame support
Old Aug 1, 2007 | 09:54 AM
SuprJames's Avatar
SuprJames
Flares? That was last weekends and probably the next few weekends project. Luckily I have some guys alot more skilled then I am helping (I mostly stand back and watch).
Old Aug 1, 2007 | 04:12 PM
Edzred72's Avatar
Edzred72
Corvette America panel purchased from Forum member that fit very well. Trimmed just a fuzz to fit tight.
Eddie
Old Aug 1, 2007 | 09:50 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Mine had the original panel glassed over, front and back on each side before the last paint job. Came out really nice, even up close. I had to look at it from underneath to see what they had done.
Old Aug 1, 2007 | 10:10 PM
BB72's Avatar
BB72
Jeez...those flares look sweet. Where did you get those?
Old Aug 2, 2007 | 10:26 AM
SuprJames's Avatar
SuprJames
They're originally the L88 flares that ACI sells. I believe I got them from Mid America though because they were cheaper. They are very modified though. The lip at the edge that wraps around wasn't there, and we cut one flares in half (you can see it in the pic) so that it wouldn't leave a huge gap in the rear like you see on most Vettes with these flares. I'll probably have a post up on it next week with some before and after shots of the flares and all the work those guys did to make them fit right.
To Rear filler panel Question
