am I missing a smog pump??
Old Aug 1, 2007 | 10:40 PM
lookin4C3's Avatar
lookin4C3
Default am I missing a smog pump??
Aside from all the other incorrect stuff... Car is a 72 w/ L48 and auto. No air cleaner comments please...
Old Aug 1, 2007 | 10:48 PM
kdf1986's Avatar
kdf1986
look at the exhaust manifolds. If you had a smog pump then there should be 4 bolts where the smog pipes came out of to connect to the smog pump. Once this unit is unbolted from the exhaust manifold, then some type of pipe thread bolts need to be screwed into the holes.
That could be one indication if a smog pump was used.
Of course the easiest way is the one answer I dont have. Was a smog pump used on a 72 vette or not.
kdf
Old Aug 1, 2007 | 10:52 PM
Jon Hekking's Avatar
Jon Hekking
Default Smog Pump
Unless yours is different from the repair manual I'm looking at, you are missing your smog pump. Should be on top between your compressor and alternator. That is of course if they used one in 1972, that I don't know.
Old Aug 1, 2007 | 10:59 PM
RunningMan373's Avatar
RunningMan373
And it starts,,,,
Old Aug 1, 2007 | 11:00 PM
lookin4C3's Avatar
lookin4C3
The guy who put the Holley on probably threw it in the trash with Q-Jet! I'll check the manifolds, maybe only some states and engines got them in 72.
Old Aug 1, 2007 | 11:29 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Default missing smog pump
I believe that in 1972 only 454 engines and LT-1 engines came off the line with smog pumps installed.Also called A.I.R. pumps or air injector reactor ( I Think).So to answer your question, I don't think your vette ever had one.
Regards
Roy
Old Aug 1, 2007 | 11:45 PM
SIXFOOTER's Avatar
SIXFOOTER
Your also missing an air filter on the passenger side valve cover which means the PCV valve is suking crap into your engine
RunningMan373
2 things to note,, 1 get rid of that under hood maltov cocktail waiting to happen ASAP! repalce it with 3/8" fuel injetion rated fuel hose ASAP,, unless you like roasting marshmellows,, also the charcol canistor and vac advance are swaped,, the upper vac line on the 4175 is a staged vac, specificly for the dist vac advance,, it's in the carb paper work.
Old Aug 1, 2007 | 11:48 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Regards
Roy
No smog pump on 72 L48.
Old Aug 2, 2007 | 12:17 AM
lookin4C3's Avatar
lookin4C3
Thanks for the replies and tips. Once the car is in my possession I'll get the bugs straightened out.
Old Aug 2, 2007 | 08:59 AM
gdm78vette's Avatar
gdm78vette
I believe that silver tag near the brake booster is the emissions tag and will list what was installed on the engine including if it had an A.I.R. pump.
Old Aug 2, 2007 | 10:46 AM
Streamline's Avatar
Streamline
Call Ken Carter (Carters Corvettes) in Livermore. CA. He fought the great state of Kalifornia (CARB) about smog stuff on Corvettes about 15 years ago. The L48s with Federal emmision did not have smog equipment. But perhaps the few that were originally purchased out here and delivered in Kalifornia back in 1972 were forced to be purchased with that fine technology.
Old Aug 2, 2007 | 02:08 PM
LYLE's Avatar
LYLE
Well the NCRS manual says in 72 all base 200 hp and LT-1s had smog pumps from the factory. Check the emissions tag near the power brake booster and see if it reads AIR. They are not wrong very often so check it out.
Old Aug 3, 2007 | 08:39 AM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Lyle,
Going from memory here, but if I recall correctly the only Corvette that did not receive the A.I.R. equipment in 1972 was the non-California base engine/automatic equipped cars. I'm also pretty sure that the current NCRS TIM&JG states this as well. If this car was delivered outside of California, I'd say that it is OK without the A.I.R. equipment.
Two comments...
The car looks really nice in the photos... Lots of factory equipment in very good shape. A nice factory style air filter assembly would look really good on that car.
As mentioned previously, the fuel filter/rubber hose arrangement is a disaster waiting to happen. Replace it with a factory style hard line from the fuel pump to the carburetor. If you absolutely must have an in line filter, you can adapt a 1968-1969 style line and use the reproduction filter.
Regards,
Old Aug 3, 2007 | 08:51 AM
LYLE's Avatar
LYLE
[QUOTE=Rowdy Rat;1561340469]Lyle,
Stan
That information was from the fourth edtion 2006. Check it out as thats the way I read it and why I said it usaally has the correct information. In later years some automatics had no smog.
Lyle
To am I missing a smog pump??
