'Extra' repairs while 'in the area'?
Old Aug 2, 2007 | 10:17 PM
Nvts's Avatar
Nvts
Default 'Extra' repairs while 'in the area'?
I started messing with the half shafts.
while I had them off, I pulled the arms off, and will be putting a new spring in. but since I have to move the exhaust anyways.....
I'll probably drop the tank and inspect it.
After that, who knows what might get fixed, just since I am in the area.
I wanted to see what some folks didn't plan to do, but just couldn't help it once they had something else out...
Old Aug 2, 2007 | 10:19 PM
Durango_Boy's Avatar
Durango_Boy
My car started with a leaky caliper. It's still in pieces in the garage getting everything from a new interior to suspension and breaks, and lights and wiring and everything else in between.
I say go for it. Get the shafts done and anything else that looks like it needs attention.
Old Aug 2, 2007 | 10:35 PM
Ron R's Avatar
Ron R
I know exactly what you mean. I wanted to get a little more acceleration from a dead stop so I figured I would change out the gears from 2.whatever to 3.70's. Not really my area so I took it to the shop and then it's like "You know, while you've got it up there"... ended up redoing the leaf springs, new shocks, all new bushings, U-Joints, basically everything in the rear end that had any wear to it was replaced.
But then you know, I'm going to lose some of the top end by doing this so I figured what the heck, the shop already has the car, I could switch out the transmission for a 700R4 with overdrive. And what the heck, lets throw in a shift kit and get this thing rockin. Gotta take the exhaust out to do that, so why not do new exhaust and new headers too. Hey, what's that leak? Oh, ok, just the radiator hose... replace that too. And what the heck, it smokes a little when I start it, might as well take care of the valve seals while I'm doing all of this other stuff...
When I bought the gears, I was expecting to spend about $500 overall. So far I'm in it for about $3,500, but damn it's going to be smooth when I get it back on Saturday. Meanwhile, I'll be working on finishing the tree house I was building for the kids so I can move into it when my wife finds out :P
Old Aug 2, 2007 | 10:44 PM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
Just posted this in another thread
This started as a spring replacement
Ended up
-rear end overhaul
-new u joints and overhaul of half shafts
-dual mount adjustable composite monospring
-bilstien shocks
-sp performance sloted rotors
-new offset trailing arms rebuilt with SS e brake rebuild
-all new poly bushings
-abjustable struts w/heim ends
-crossmember bushings
-new gas tank
-new SS exhaust
-all kinds of hardware
-and soon a set of new Willwood calipers from corvette engineering
I need more money so I can tackle the front end Think I will replace the a arm bushings....and mabe a front monospring....and rack and pinion conversion... And well you know the rest I cant control myself!!!!
To 'Extra' repairs while 'in the area'?
