Need help identifying engine
Old Aug 7, 2007 | 09:19 PM
InsaneLane's Avatar
InsaneLane
Default Need help identifying engine
I just purchased a '72 coupe and the code on the block reads
V0626CNU. What is this engine from? It is apparently not numbers matching... Thanks.
Old Aug 7, 2007 | 09:51 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
A quick google search shows a 1970 350, 250hp, 2 barrel, powerglide. It's a screamer. :o
Old Aug 7, 2007 | 10:09 PM
7T1vette's Avatar
7T1vette
Base engine from the Chevy line....
Old Aug 8, 2007 | 12:36 AM
dgruenke's Avatar
dgruenke
In addition to the above, it came in the full size cars.
Old Aug 8, 2007 | 08:05 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I had one of those out of a station wagon in my Camaro in the early 70's. With headers and a holley 2 bbl it really was a screamer. High 13's with a 3.90 Posi, N-50-15's and M-20. Raced Super Stock class and really suprised a lot of people with it.
Old Aug 8, 2007 | 08:12 AM
olds120's Avatar
olds120
Default engine id
http://www.nastyz28.com/decode.html
try this link it has alot of info
i liooked it up for you.
1970 350/250 hp auto , 2 brl, full size car
Old Aug 8, 2007 | 09:49 AM
InsaneLane's Avatar
InsaneLane
Thanks for all of the replies. I was under the impression that it was a #'s matching car when I purchased it. I don't know that it is the end of the world since this engine has 50 more HP than the original. I recently ordered some new Hooker headers from Jet-Hot so I hope they fit ok on this engine. Are there any major differences between this engine and the stock engine?
Old Aug 8, 2007 | 12:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by InsaneLane
...V0626CNU...
V0626CNU is a GM engine identification code.
V plant code for the Flint, Michigan, engine assembly plant. All Corvette smallblocks were assembled at Flint, but so were engines for other GM cars and trucks.
0626 calendar date engine was assembled, June 26th
CNU application suffix, generic Chevrolet passenger car. Unfortunely CNU is not a Corvette engine code.
The pad where this code is stamped should also contain a VIN derivative of the first car the engine was installed in. That number will contain a code for the vehicle assembly plant and from that you could determine where this engine came from.
Old Aug 8, 2007 | 01:50 PM
ROBMERRILL's Avatar
ROBMERRILL
1972 Engine Identification Codes:
Engine Code Cubic Inches Order Code H.P. Applicable Equipment
CKW 350 Base 200 Rochester Q-jet & 4-Speed
CDH 350 Base 200 Rochester Q-jet, NB2 & 4-Speed
CKX 350 Base 200 Rochester Q-jet & Turbo Hydra-Matic
CDJ 350 Base 200 Rochester Q-jet, NB2 & Turbo Hydra-Matic
CKY 350 LT1 255 Holley 1x4BC, Mechanical Lifters, & 4-Speed
CRT 350 LT1 255 Holley 1x4BC, Mechanical Lifters, K19 & 4-Speed
CKZ 350 ZR1 255 Performance Package, LT1 Engine & M22 4-Speed
CPH 454 LS5 270 Rochester Q-jet, Hydraulic Lifters & 4-Speed
CPJ 454 LS5 270 Rochester Q-jet, Hydraulic Lifters & THM
CSR 454 LS5 270 Rochester Q-jet, Hyd. Lifters, K19 & 4-Speed
CSS 454 LS5 270 Rochester Q-jet, Hyd. Lifters, K19 & THM
Old Aug 8, 2007 | 09:08 PM
InsaneLane's Avatar
InsaneLane
Thanks again for all of the posts! I scracthed the other number and found 10S242386. Let me know if you have any idea what this engine is out of. Thanks.
Old Aug 8, 2007 | 09:16 PM
ratflinger's Avatar
ratflinger
Some Chevy boat. Something like a Biscane. I didn't even remember GM still using powerglides in 70, but I guess so. Could have been a Camaro or Nova, who knows.
Old Aug 8, 2007 | 10:27 PM
Secret Squirrel's Avatar
Secret Squirrel
I doubt it In '70 engines were measured using SAE Gross hp and in '72 it was changed to Net, so it's probably around the same
If you were led to believe that it was numbers matching, i'd be having a good **** and moan at the seller.
To Need help identifying engine
