will it fit?
Old Aug 9, 2007 | 11:38 PM
nowherefast792's Avatar
nowherefast792
Default will it fit?
Will a 77's trailing arm and/or wheel bearing assembly fit on a 68. In the Corvette store they have them listed as 65-76 and 77-82??
Old Aug 10, 2007 | 12:48 AM
Procrastination Racing's Avatar
I don't know of any difference as far as them fitting. The emergency brake cable bracket moved slightly on some, I believe to give better clearance on the 255/60-15 tire option, but I don't know of any other change offhand. I have swapped years between those groups without issues other than readjusting the length of the emergency brake cable.
Old Aug 10, 2007 | 12:55 AM
Trucks_69's Avatar
Trucks_69
i believe in 1977 they changed a few things in the rearend... and i'm pretty sure the upper crossmember is different...
i'm sure you could make them fit a 68 but some modification might have to be done
Old Aug 10, 2007 | 05:18 PM
nowherefast792
I am actually just going to reuse my trailing arms and get the wheel bearing assemblies. Someone near me is parting out a 77 and they are letting stuff go pretty cheap.
To will it fit?
