82 Vechicle Speed Sensor?
Old Aug 11, 2007 | 01:21 PM
hugie82's Avatar
hugie82
Default 82 Vechicle Speed Sensor?
Hi all, I have an 82 vette all stock and the trans converter is acting up. The guy at the local tran shop said its the VSS (vech. speed sen.). Here's my problem, I can't find its location. I even checked that book looking thing (manual) It mentions it with code 24 but no referrence to where it is. If anyone knows please help THANKS.
Old Aug 11, 2007 | 02:49 PM
TheBottomLessPit's Avatar
TheBottomLessPit
Cruising
Hope this helps
Old Aug 11, 2007 | 05:42 PM
SIXFOOTER's Avatar
SIXFOOTER
The pic has most of it, the VSS itself is on the back of the speedo
Old Aug 11, 2007 | 07:42 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Pull your instrument cluster, it's attached to the back of the speedometer, it's letter "A" in the picture.
Old Aug 13, 2007 | 08:46 AM
hugie82's Avatar
hugie82
Default You Guys Are The Best!!
THANKS TO EVERYONE!! you all came through for me. Hopefully I can find out why my tran TCC locks up as soon as it hit 2nd gear I don't think its the lockup switch in the trans because when I tap the brake pedal it disengages instantly. THANKS HUGIE82
Old Aug 13, 2007 | 08:55 AM
SIXFOOTER's Avatar
SIXFOOTER
It might be the pressure switch in the tranny, the VSS sends a reference to the CCC, the CCC decides when it is happy enough with the engine and speed to lock, but the pressure switch should hold it off until your in 3rd or 4th
Old Aug 13, 2007 | 09:25 AM
hugie82's Avatar
hugie82
But isn't the pressure switch the same switch thats activated when I trigger the brake light switch?
Old Aug 13, 2007 | 09:51 AM
SIXFOOTER's Avatar
SIXFOOTER
No, the pressure switch inside the tranny controls the ground side of the solenoid. As I understand it, the pressure switch gets made when the tranny is in 3rd or 4th, providing a ground path for the solenoid. At that point the converter can go into lockup provided the CCC says its ok. The CCC bases that decision on engine temp, speed, and probably RPM. That signal goes thru the brake pedal switch and then to the tranny.
Old Aug 13, 2007 | 10:00 AM
Jim Martley2's Avatar
Jim Martley2
Early converter lock-up is a common problem witht 82 Corvettes. I bought an aftermarket computer chip for mine and it made a day and night differance in the drivabulity of the trans. The converter would lock up at 30mph in 3rd gear and damn near stall the engine with the OEM chip in it.
Old Aug 13, 2007 | 01:46 PM
hugie82's Avatar
hugie82
YES, Thats what is happening! I ordered a chip stage one from corvette central (hoping it will get here today). If I still have the disengagement problem I will pull the pan & check the pressure switch. THANKs for all your imputs!!
Old Aug 13, 2007 | 02:19 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmm, learn somethingnew everyday in here
Old Aug 13, 2007 | 02:37 PM
hugie82's Avatar
hugie82
Default YOU still maybe right
If this trans still doesn't disengage with the gas pedal being depressed. I'm also looking into the distributor module(7 pin w/ electronic vacuum adv), it also has a switch to the TCC. Will all figure this out sooner or later!!!
Old Aug 14, 2007 | 09:30 AM
Jim Martley2
If your car still has the original distributor and fuel injection, it will NOT have a vacuum advance cannister on the distributor.
The chip I use in my own 82 and have installed in other 82s , with excellant results, is the "ThermoMaster" by Hypertech. It requires a 160 degree thermostat be installed. You also HAVE to run Premium gas in the car at all times.
Jim
To 82 Vechicle Speed Sensor?
