Slow setting bonding adhesive
http://s120.photobucket.com/albums/o190/coinwasher/
http://www.lord.com/Home/ProductsSer...1/Default.aspx
You might be able to find Pliogrip at an aftermarket autopart store but doubt that Ashland would sell any adhesive to the general public. The Lord Fusor that was mentioned is an epoxy. I would sand any composite parts prior to bonding. Blow the dust off and make sure all the parts are clean. Apply a lot of adhesive and make sure you don't clamp to hard thus starving the bondline of the adhesive. Epoxies in the automotive industry usualy are cured with heat during a post bake or cure at room temperature. Only issue with curing at room temp is it takes a very long time to reach full streght. Just make sure you keep the parts clamped.,
My adhesive is a methacrylate based adhesive which is used throughout the transportation industry. You can pick it up at any home center under the brand "Plastic Welder". It cures very fast and should only be used for small parts. It has the strength of the Lord Fusor product with the flexibility of the Pliogrip.
Good Luck!
I helped a friend glue an ecklers fender on a '78
He purchased a Fusor product to attach the fender to the front metal support. stuff was very slow drying (12-24 hrs iirc) felt like silicone when dry. (was really unsure of the quality)
After it was dry we bonded the back of the fender with an Ecklers product
it hardened too fast .fender was out from the door a bit.
We figured we'd remove and reglue.
we broke it loose at the door
the fusor held so well, we would probably trash the fender,so we left it alone.
pulled it out 12-18" (still amased that the front was holding )
reground the bonding surfaces, and reglued the fender with a weaker batch.
v-groove and glass the splice thru headlight, 4 years and looks great
now he has to fix the factory gap on the other side
I screwed through the fiberglass and left it that way for about 1 1/2 days. Not because I needed to, I just didn't get back to her till then.
You can see more of how it looks here:
http://forums.corvetteforum.com/show...107000&page=24
I found the "FUSOR MANUAL DISPENSER GUN" on e-bay for about $30 bucks.
The cheapest that I found the Fusor product was here:
http://www.sherwin-automotive.com/pr...t=29609&cat=75
I had to special order it at the local store. They had it listed for about $65 but since I had the web page printed out and with me, they gave it to me for $45.
Just don't use it in California. It's been know to cause cancer there.
(Yes, it says that on the package.)
Hope this helps.
KO
PS: Let me know how many tubes that it takes you. I'll be reattaching my front clip some day.
NORTON STRUCTURAL ADHESIVE. (speed grip) You can choose from different working time
