Bouncy Headlights?
Would the 4 new tension springs solve this or is it something else?
Seriously the AIM talks about a "STOP" screw adjustment (well it doesn't call it exactly that, but that's the idea I get from what it is suppose to do). However, either my buckets are replacement buckets or the 81 didn't have these Screw adjustments. The "L" bracket is there but no screw hole and no screw with a rubber head.
This bucket keeps beating the living sh*t out of my beautiful custom paint job I had done!
However I am looking at the COrvette Central C3 book at the headlight parts section and see the adjuster screws listed.
Do they work by creating MORE tension on the spings???
Go Here: http://www.docrebuild.com/dr-r-web/HDLAMP2.PDF
Scroll down to the exploded diagram of a 68-82 headlight Housing. The parts are listed as H (L shaped bracket) and J (adjusting screw)
The back stop is there, the "L" shaped bracket on the bucket is there, there is no "Screw hole" drilled in the "L" shaped bracket and of course there is "NO SCREW" with a rubber cap. So either I have after-market buckets on both sides, which I find hard to believe or they were eliminated in or around 1981 for some strange reason.
there are 4 springs used on each headlight assembly
if any of these are missing you will loose tension
my passengers side headlight was driving me nuts on
every bump, after pulling the headlight bezel i found 3 of the 4 springs broken or gone.
the springs are pictured on the docrebuild link above under headlamp
linkage
linkage
I will go forward in those steps.
CHECK to see if the springs are there and in place.
Try tightening the adjustment screw.
If it is better then I am done, if still bouncing I will order the 4 new springs(only$10.00)
Sounds like a plan!
Sounds like a plan!
This is a diagram for a 81 which I think is no different than any other year than 68.
At the end of the actuator rod you will see threads. You need to remove all the springs and remove the pivot ball on the end of the rod. If you turn the ball counterclockwise the ball should move outwards. Try turning it two or three times. Replace it and see if housing still bounces. If it doesn't bounce your done. If it does, then try another turn till you get it right.
Make sure headlight housing is secure to body, I have seen bolts missing from collision or just driving the car over time. Make sure springs are good and that actuator is good. If all of this is fine the above will work. It will be hard to get rod back through pivot ball. If the rod just slides in to the pivot ball, it will bounce. Once you have tension on the headlight so it will not bounce. You will not hurt actuator.
In this diagram you will see the stopper rod. Look at bolt number 2
Make sure this is in place. There is a small adjustment on this. With headlight up make sure end of stopper hits housing.
Good Luck
I found it was missing a bolt where it bolts to the outside front corner of the car (by the bumper). The hole was stripped out so I installed a nut and bolt. That helped alot.
During a past repair they body man took some shortcuts. He left off the bracket that goes from the bumper through the fenderwell to the frame. The bumper was mounted just to the body - not to the bracket. He also did not bolt the headlight bracket back.
Check to see if all the mounting bolts are there and they are tight.
Its just supported from the center at this point. Could that be causing the shaking?
I knew I should have ordered the bolts a while back.
Seems like the prior owner undid everything half *** for a half *** paint job and lost many a bolt and screw.
All 4 tail lights have only 2 of the 3 screws. Side strims under the door, every oither screw. Interiors 1 of 3 or 1 of 2 on everything.
Its not like they are terribly expensive to replace either.
At least he didnt use over sized screws wedged into the holes. Last one I owned the guy must have gotten stock on oversized screws and bolts and stripped out just about EVERY hole in the car.
When I ordered the screw and bolt kits every one was too small.
BUBBA hit that car hard and I had to get rid of it.
JUST TOO MANY LITTLE THINGS SCREWED UP!
