I screwed up
Old Aug 22, 2007 | 11:21 PM
doublearrow's Avatar
doublearrow
Default I screwed up
I was checking for a drain on my battery tonight and I dropped a wrench across the terminals. Now I have now power anywhere and I have no idea where to start looking. Any help would be appreciated.
Old Aug 22, 2007 | 11:26 PM
VettePower's Avatar
VettePower
You may have just blew the battery. Do you have a volt gauge to check the battery??
Old Aug 22, 2007 | 11:42 PM
Artsvette73's Avatar
Artsvette73
You may have wacked some fusible links.
Old Aug 22, 2007 | 11:50 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
start at the fuse box
Old Aug 23, 2007 | 12:18 AM
VettePower's Avatar
VettePower
Actually, could be very true!! Check the fusable link at the starter....
Old Aug 23, 2007 | 12:54 AM
prostreet68's Avatar
prostreet68
Those fusable links can be a pita if you do not know where they are hidden. I agree check there as well.
Old Aug 23, 2007 | 01:01 AM
doublearrow
That was some fast help. Thanks. I started looking for the fusible links, but got frustrated. I had taken the negative cable off after I shorted across it then put it back on. I was reaching down to put my volt meter on it and it sounded like an arc. For some reason when I screw the side mounted cable all the way in on the negative side it loses contact. I backed the bolt a turn or two and now have power. I don't know if something is wrong inside the battery or what. Thanks for the help.
Old Aug 23, 2007 | 01:04 AM
7T1vette's Avatar
7T1vette
You could have damaged the terminal connections inside the battery. You really do need to have the battery checked out for its capability when loaded to see if it is damaged. Since it starts at all, there should be no fusible links damaged. Did it stay shorted for very long?
Old Aug 23, 2007 | 01:06 AM
doublearrow
No it didn't stay shorted long at all. As soon as it hit it bounced off.
Old Aug 23, 2007 | 01:44 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
the shorted circuit was in battery side, not the peripherals side, so why you expect a fuse blow somewhere? actually, ahorting a battery will suck the power off the car, not surging it to the car.
Old Aug 23, 2007 | 08:22 AM
RunningMan373's Avatar
RunningMan373
True, but if the short is large and high current,, and drops very quickly, the inductance in the battery could cause a huge, very short voltage spike, as the inductance tries to keep the current going. Could happen, but inductance is intentionaly kept to a minimum in a battery.
Old Aug 23, 2007 | 08:29 AM
Jims79's Avatar
Jims79
You may have gotten lucky. I did that on a 68 vert w/the hard top on & blew a hole in the battery, acid every where. You should pull out the battery & check it.
Old Aug 23, 2007 | 09:02 AM
DARROW's Avatar
DARROW
Thats right
It has to be the battery
Old Aug 23, 2007 | 09:28 AM
Stewart's74's Avatar
Stewart's74
dont feel bad. I set a pos 67 bonneville on fire when I was changing the pump to carb fuel line. The metal line touched the battery and poof! not one of my finer moments.
Old Aug 23, 2007 | 11:10 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Re- place the terminal its bad the short time the batt was shorted should not have damaged the car at all maybe just the Battor even the cable connector the fact that it workes when you un-screw it tells ya something.I found a big bolt that screwed right into the battery (on my van not my vett I would re-place it on the vet but to try it find the bolt that will thred into your batt cut all the plastic off the battery side of the connector bolt it up see if you have power .
To I screwed up
