Muncie overdrives. anyone running them
Old Aug 25, 2007 | 10:54 PM
crf311's Avatar
crf311
Default Muncie overdrives. anyone running them
Just ran across the muncie overdrive gear set from auro gear equipment. I was woundering if anyone is/has used them and what their opinion is? The geat ratio's are 2.20/1.35/1.00/0.87.
I wounder how they would work with a 3.08 rear end? any thoughts?
Old Aug 26, 2007 | 12:40 AM
DZRick's Avatar
DZRick
You got a link to their site you can post for us?
Old Aug 26, 2007 | 01:53 AM
7T1vette's Avatar
7T1vette
The car would be a "dog"...but it would get great gas mileage.
Old Aug 26, 2007 | 02:09 AM
FRSTR90's Avatar
FRSTR90
2.20 and a 3.08 = a terrible 1st gear.... I think it would be great with a 4.11 though!
Old Aug 26, 2007 | 07:22 AM
crf311's Avatar
crf311
I'm not worried about 1/4 mile times, since I have never beeen to a drag strip. I 'm more interested ingas milage and highyway cruising. I'm sure someone runs a std muncie with a 3.08 rear who can tell us about the take off's. Here is the link www.autogear.net.
Old Aug 26, 2007 | 02:19 PM
72 LT1's Avatar
72 LT1
Most guys that run 3.08, 3.23, or 3.31 gears use a wide ratio transmissions, like an M20 or a Super T10. There steeper 1st, 2nd, and 3rd ratio's make up for lack of rear gear torque multiplication. When used w/ small block engine, I personaly wouldn't use a 2.20 1st gear w/anything less than a 3.70 rear. Just my .02.
Old Aug 26, 2007 | 02:54 PM
DZRick's Avatar
DZRick
Quote from their site
"Which brings us to the M21Y, the overdrive you've heard about. It's not for everybody, but if you're running an M21 with a 4.11 or higher, it may be for you."
Sorta says it all.
Old Aug 26, 2007 | 05:02 PM
big_G's Avatar
big_G
My original L-79 '68 had 3.08 rear with a close ratio (2.20 first). It would turn mid-14's pure stock. I would say for you it might work out fine.
Old Aug 26, 2007 | 07:50 PM
yooperod's Avatar
yooperod
the .87 od should drop the rpm @ 60mph by about 300.
the trans seems pricy enough , is the conversion kit economical?
early OD tranmissions seemed to have a lot of bearing problems
not sure how well a conversion would hold up.
I went with a tko w/3.55 rear gears
with it's 3.25 1st gear will be switching back to 3,08 in the future
rod
To Muncie overdrives. anyone running them
