off set t-arms
Old Sep 5, 2007 | 04:59 PM
d1cross's Avatar
d1cross
Default off set t-arms
can you guys tell me if when using offset t-arms do you need to use a shorter rear spring ? if so where could i buy one?
Old Sep 5, 2007 | 05:21 PM
Gordonm's Avatar
Gordonm
No. You can use the stock size spring. If you use a shortened spring you can use double offset which moves the spring mount in some. Standard offsets do not need a shorter spring.
Old Sep 5, 2007 | 11:51 PM
spf72's Avatar
spf72
You don't have to but you can change your spring - I am going with coil overs and not using the regular spring at all.
Old Sep 6, 2007 | 12:16 AM
sly vette's Avatar
sly vette
What do you have in mind for the coil overs as far as installation?
Sorry for the mini jack!!
Old Sep 6, 2007 | 02:59 AM
Z-man's Avatar
Z-man
Those TAs can be used with all the stock stuff, but now's the time to upgrade as long as it's all apart.
To off set t-arms
