Frame Compatibility
Old Sep 6, 2007 | 08:46 PM
SpeedCoach's Avatar
SpeedCoach
Default Frame Compatibility
Gang - I searched and searched for a good answer but didn't find one (maybe I was using the wrong terms)
The body of my 76 is coming off in the next couple of weeks...i have no reason to think anything is wrong with the frame (matter of fact it appears to look pretty good) but if I've learned one thing with these cars it is that there is always a surprise lurking underneath....
So assuming my frame turns out to be rotted all to heck somewhere, I'm curious as to what frames are compatible with the 76? does "any" C-3 frame work (i did see some posts about the bumper areas, does that affect fit?)? will a 75 work but a 72 won't?
Appreciate the help - who knows, maybe I'll get lucky and this will be all for naught...
Old Sep 6, 2007 | 11:03 PM
72LS1Vette's Avatar
72LS1Vette
74 and newer should work for your car. Chrome bumper Vettes have a different rear section and frames are generally a lot more expensive since there are fewer of them available. You can probably find a good condition frame for well under $1,000 if you need one.
Rick B.
Old Sep 6, 2007 | 11:45 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
This website lists the changes from year to year.
http://forums.corvetteforum.com/newr...1&p=1561814747
Old Sep 6, 2007 | 11:58 PM
67-73-76's Avatar
67-73-76
Default Frames
75-76-77 frames are the only direct replacements for each other.
Earlier or later frames will require modifications to work under your 76.
Old Sep 7, 2007 | 09:24 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
http://www.71corvette.com/frames.html
Add this to your Favorites.
To Frame Compatibility
