Spark Knock
Old Sep 9, 2007 | 10:27 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Spark Knock
77 Vette, L-48, stock except headers, Lars distributor upgrade, and intake. Timing is right and run mostly the 87 octane gas and never had a problem. I've changed to 93 octane and added STP Gas Treatment hoping to stop the spark knock. Didn't work!!
Any suggestions?????
Thanks in Advance!!
Old Sep 10, 2007 | 07:24 AM
Durango_Boy's Avatar
Durango_Boy
Is the balancer stock? If the balancer has slipped then timing will be off even if it looks like it's dialed in.
Old Sep 10, 2007 | 08:20 AM
dmaaero's Avatar
dmaaero
have you tried retarding the timing a couple degree"s
Old Sep 10, 2007 | 12:57 PM
BKbroiler's Avatar
BKbroiler
Try disconnecting, and plugging, your vacuum advance, temporarily. If the knock stops, you have too much total timing.
Old Sep 10, 2007 | 07:03 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
New balancer and timing chain!
Old Sep 10, 2007 | 07:05 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Yes!
Old Sep 10, 2007 | 07:18 PM
Durango_Boy
Are you sure it's pinging you hear? Have you pulled your valve covers to make sure all the rockers are positioned and aligned properly and to check for any collapsed lifters?
To Spark Knock
