Transistor Ignition problems
Old Sep 11, 2007 | 11:01 AM
LT1Kenobi's Avatar
LT1Kenobi
1st Gear
Default Transistor Ignition problems
I have trouble starting my 71 LT1 (with original transistor ignition) AFTER it's already warm....like at the gas station. I replaced the transistor box with factory parts maybe ten years ago.
Anyone had similiar problems? Solutions?
I'm going to replace the battery cables first. When I bought a new battery and replaced the terminal connectors, I noticed that the wires were corroded inside the plastic sleeve. Warm start problem persists after changing the battery.
Thanks!
Mark
Old Sep 11, 2007 | 01:27 PM
halfmoontrail's Avatar
halfmoontrail
More likely a starter problem ("heat soak"). Make sure the factory heat shields are in place.
Steve
