1980 air dam
Old Sep 11, 2007 | 07:17 PM
bt57's Avatar
bt57
Default 1980 air dam
need a clear photo of a 1980 rubber air dam that mounts under and behind the front bumper, i am missing some parts and not sure what i need to put it back in, i think i am missing the lower extension air dam that blocks off the air below the radiator and the 2 rubber spoiler extentions
Old Sep 11, 2007 | 07:49 PM
aussiejohn's Avatar
aussiejohn
Default Aim
bt,
Get yourself an Assembly Instruction Manual and not only does it have drawings of the parts and necessary bolts and brackets, etc. but also their factroy part numbers, Some say that a photo is worth a thousand words, but you can't go past a factory part number if you want the right part.
Regards from Down Under
aussiejohn
Old Sep 11, 2007 | 09:09 PM
SIXFOOTER's Avatar
SIXFOOTER
Here is the stuff you need
http://www.ecklers.com/product.asp?p...2&dept_id=1359
2 piece air dam extension, its split in the center
This is the big plastic piece under the chin that directs most of the air
http://www.ecklers.com/product.asp?p...0&dept_id=1353
There are some SS strips that go on there to backup the bolts too. Ecklers doesn't seem to list them
Here is the retainer strip, 2 per
http://www.zip-products.com/Zip/prod...8405D47FBA79EB
Old Sep 12, 2007 | 06:53 PM
bt57's Avatar
bt57
Default thanks for the help 6 footer
I have assembly manuals but the angle and the detail is not clear, the parts links are just what I needed, once again thanks for the help
Old Oct 7, 2007 | 10:39 PM
bhunter's Avatar
bhunter
I have a similar type question about the 1982 spoiler/air dam. I have the replacement parts. When I started to remove the old spoiler, it appears as thought sheet metal/self tapping screws were used to attach the outside edges. Is that correct? The hardware kit came with ten (10) bolts only.
To 1980 air dam
