Amps + Watts = ?
. I'm upgrading to the Pioneer 7900 series radio, and I'm running 2-6x9 Infinity 3 way (300w max)and 2-4x6 Infinity 2 way speakers (120w max)in the rear, and 2-4x6 Infinity two way speakers (135w max) in the dash. I'm thinking of installing an amp and was wondering if the alternator will handle it without any additional upgrades?
Yes with ***'s. The radio will not pull all that much more amperage. The max wattage is not something you should ever evaluate a speaker and amp combo with. You will never reach max wattage unless you have a heavy metal rap duet playing at maxed out all the way hard over volume.
You probably have about 150 - 185 watts or RMS draw. I would put that right around a 20 amp draw from the charging system. Now, with headlights and HVAC stuff running you will be pushing that alt to the limit but it should work just fine.
That being said, it's always a good idea to install a better alt. Reason being, that 70 amp probably puts out somewhere south of half that at idle. That means at a stop light you will have dimmed headlights and will be running off of the battery. Not good for battery life.
I suggest a CS130. They are cheap and very easy to install so long as you get a 12 & 6 clocked case CS130. Here's a paper to aid in the installation.
http://photos.imageevent.com/durango...%20Install.pdf
On a final note, those six speakers will probably have a hard time playing well with one another. In a cabin the size of a C3, you really only need a good solid front stage. The front speakers you picked may not be best suited for solo duty in a lout open air car like a Corvette so adding some rear speakers will definitely help. I would however, try to talk you out of using the third set of speakers.
Put the pair of larger more powerful speakers in front, and the smaller less powerful speakers in the back. Amp them, and call it a day.
Used to be, the manufacturers would simply rate the speakers or amps at twice RMS and call it peak,, but now they're hiting them with the max power it can survive, it looks like, and putting it on the box as some real rating. max power. Meaningless. My 30 watt RMS Pioneers were rated at 120 Watts, peak, real big, on the box. in the fine print,, or specifacations it says 30W RMS. Allways ask what the RMS or continous power is, and build the system around this,, anything else is pure fantasy. Some of those stereo sales people don't know thier ykw from a hole in the ground,, so allways check the box before you buy for RMS power rating,, esp on Amps. Also check what Impeadenmce a power amp delivers it's power to. sopme will be 4 ohms, some will be 2,, some older ones will be 8, 8 used to be the standard,, now it's 4. That's important because if you go with twice the rated resistance (same as impeadence)in a speaker, the power you will get out is only 1/4 the rated power.
eg: If your amp says it delivers 200 watts into a 2 ohm sub and you hook up a 4 ohm sub you get,, that's right, 50 watts of power out of it. nothing you can do about it either. just bear these facts in mind,, i'd say that 75 clean watts of power into each of 4 speakers would be plenty good enough for even the most jaded listener,, and will sound great if you use quality componants and position them right.
Let me know if you would like some help choosing an amp.
Easy. say some kid just got himself a Honda Civic, a wong, fart can, and a few stickers. He walks into Wal-Mart for his stereo equipment. Do you think he's going to buy a set of Boston Acoustic 6.5" 75 watt speakers or will he purchase the Sony Xplode 6.5" 300 watts speaker set for $40 less than the BAs? It's all marketing. They know that by slapping a huge wattage on a low quality speaker they will sell more even though they are rated at the same RMS wattage.
As an aside, depending on when you played bass, you might have had a tube power section in your amp which can put out its full rated power and sound good. A solid state amp pushed past clipping is not pleasing to the ear and most solid state amp begin clipping well before their max power rating.
Speaking of power rating, I also think that many current amps have inflated power ratings. Even though an amp can make its max power, if it can only do so for a moment before releasing the magic blue smoke what good is a max rating?
Okay, that's it. I'm done talking for now.
Here, this may help with the picture posting.
http://photos.imageevent.com/durango...g%20Images.pdf
Don't thank me,
, thank Photobucket. Most car audio makers thrive on hype. The good quality stuff is almost always going to be a brand you can't find at local stores.
There are premium brands out there that make a $6,000 set of three way components. How's that for sick?
. I checked the boxes of the speakers and the 4x6's RMS are 40w & 45w. The 6x9's are 100w, and the Pioneer stereo is rated at 50w x 4
. When I installed the 45w 4x6's in the dash I turned on the radio when I had one new speaker, and one original one in, and the new one sounded so much better compared to the original speaker
