Jumpy Ammeter Gauge
Old Sep 29, 2007 | 01:25 AM
hzz's Avatar
hzz
Well, I finally got the answer to my jumpy ammeter gauge.
Tonight my left turn signal didn't blink. I thought it was the bulb of course but a new bulb didn't solve the problem.
After changing the bulb and monkeying around with it for a bit, I noticed that the turn signal indicator on the dash would light up when the headlights went on. Then it wouldn't.
To make a long story short, after 3 hours or so I traced it to the socket that connects the parking light to the wire harness. Didn't see any way of taking that socket apart(rubber boot) so I cut into the wires and spliced them together.
Not only does the turn signal work, but the ammeter gauge works perfectly,too!
Now it's time for bed....................
Old Sep 30, 2007 | 08:33 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by 7T1vette
Could be a grounding problem, but more likely a voltage regulation problem (internal to alternator).
mine did this for some time.........then eventually the car died !!!
it was the voltage regulator, after replacing it the ammeter was steady again !!!
