Hide Away Wipers
Old Sep 21, 2007 | 09:08 AM
Toms-68's Avatar
Toms-68
Default Hide Away Wipers
Help please. I have a 1968 totally restored convertible and my wiper cover will not close. It has worked after the resto until last Sunday when I was out driving. It popped up and will not close. Could it be the limit switch? Any help would be appreciated.
Thanks, Tom
Old Sep 21, 2007 | 09:19 AM
jude's Avatar
jude
Can you hear a hizzing like a vacuum leak inside the car? The first thing I would check are your vacuum connections at the over ride swith under the dash.
Old Sep 21, 2007 | 09:25 AM
R1234's Avatar
R1234
Check all vacuum connections. Also, use this as trouble shooting guide.
http://www.corvettefaq.com/c3/1968Wiper.doc
http://www.corvettefaq.com/c3/68wiperts.xls
Bryan
Old Sep 21, 2007 | 09:26 AM
Toms-68's Avatar
Toms-68
I do not hear anything and did try the by-pass switch. I can close it with my hands and when I start the car it opens up again.
Tom
Old Sep 21, 2007 | 10:40 AM
Toms-68's Avatar
Toms-68
Thanks Bryan for the trouble shooting guide, The guide says it might be the Vacuum solinoid.....do you know where that is located?
Tom
Old Sep 21, 2007 | 10:47 AM
Theiskell's Avatar
Theiskell
Check the Limit switch, you are on the right track there. That is just a normally open switch. For a test just jump across the two wires that go to it and start the car. Or if you know how to use a meter check the switch for continuity with the button pushed down. If you see continuity the switch is good…..well at least that is not what is keeping the door from going down. Good luck.
Old Sep 21, 2007 | 12:49 PM
R1234's Avatar
R1234
Tom
Wiper door solenoid is mounted on the back of the tachometer.
Bryan
Old Sep 21, 2007 | 07:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Vacuum problem, not the limit switch. Limit switch only powers the wipers when the plunger closes the switch.
Check the vacuum relay on the right fender skirt before you plunk down the bucks for a solenoid.
Old Sep 21, 2007 | 10:21 PM
7T1vette's Avatar
7T1vette
There is a wiper limit switch which is mounted horizontally to the wiper motor....and there is a wiper DOOR limit switch which is mounted below the right side wiper. If this switch is not "made", the door will not close. (The system thinks the wipers are still "up"....) There are a number of things which can cause this, but the wiper DOOR limit switch, its adjustment, or feed to that switch are the primary possibilities.
Old Sep 21, 2007 | 11:03 PM
DZRick's Avatar
DZRick
Not on a 68
To Hide Away Wipers
