engine codes
Old Sep 25, 2007 | 07:42 AM
tbschilz's Avatar
tbschilz
Default engine codes
I got my # off the block where do I go to see if its original need help
Old Sep 25, 2007 | 07:55 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
The last 6 numbers of the engine code will be the last 6 of the VIN if the engine is original, assuming they haven't been tampered with.
Old Sep 25, 2007 | 08:07 AM
tbschilz's Avatar
tbschilz
Default match
thank u very much # match, what r the # below the engine codes stand for I've got a crate engine to replace the original just wondering,the one I just got is supose to be the same anyway to tell
Old Sep 25, 2007 | 08:22 AM
Jud Chapin's Avatar
Jud Chapin
Put all the numbers on the block pad in a thread and someone will break them down for you.
Old Sep 25, 2007 | 05:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
There a two numbers stamped on the engine pad. The first (and largest) is the engine identification code stamped at the engine assembly plant (Flint, Michigan for Corvette small blocks and Tonawanda, New York, for big blocks).
The second number (smaller characters) is the VIN sequence and was stamped on the assembly line.
The Corvette Black Book lists the engine codes.
Old Sep 25, 2007 | 06:35 PM
Bric's Avatar
Bric
OK, the small #'s are to coincide with the VIN # if the car is #'s matching. We have that much straight. What does the second set of BIG #'s mean??
Like V07290 CKX
I know the CKX means 180HP auto-tans. What's the first part mean?? I don't mean to hijack a thread just curious....
Old Sep 25, 2007 | 08:11 PM
Duke94's Avatar
Duke94
Example: V0621CTU Typical 1970-82.
V= Assembly plant (V=Flint,T=Tonawanda)
06=Assembly month
21=Assembly day
CTU=Motor Division and Suffix code CTU= Chevy 370HP 350 LT1 4 speed)
Source: Corvette by the Numbers 55-82.
To engine codes
