backfire when engine revs down
Old Oct 3, 2007 | 03:02 PM
zz4sting's Avatar
zz4sting
6th Gear
Default backfire when engine revs down
has anyone else had problems with engine backfiring when engine rev's down. what has changed was that i replaced the vacuum canister and connected hose to vacuum port on intake manifold. checked timing,ok.runs great until i let engine rev down, at about 25000 rpm's i get a couple pops threw the exhaust. any idea's on what's wrong. engine is new zz4, 4 speed trans. 1974 stingray. i'm new to the forum.
Old Oct 3, 2007 | 03:15 PM
guitarcrazy02's Avatar
guitarcrazy02
What kind of exhaust are you running? Mine does the same thing. I think it's kind of normal if you have a more open exhaust, as it's just unburned fuel firing in the exhaust. On cars with normal/more restrictive mufflers, it quiets it down so you can't hear it. But when you open up the exhaust, you can hear it. That's why you see flames out the pipes of race cars when they let off before a turn.
At least that's what I think...
Old Oct 3, 2007 | 04:51 PM
7T1vette's Avatar
7T1vette
Do you mean that you removed the vacuum cannister? If you did, you've created a situation which the car's design never intended. The vacuum tank is an "accumulator" which helps to stabilize the vacuum level under various manifold conditions. If you did not remove the cannister, make sure there are no leaks or loose hoses. As this just started since your vacuum "work", it is likely the cause....either because the system has changed the operating behavior of the engine, or because there is some improperly connected/installed component.
Old Oct 3, 2007 | 05:30 PM
guitarcrazy02
I must have skipped the part about the vacuum cansister. But if everything there does check out, then my money's on exhaust. But yes, I'd check to make sure you've got everything hooked up properly and no leaks.
Old Oct 3, 2007 | 08:24 PM
zz4sting's Avatar
zz4sting
6th Gear
you might be onto something. I have a chambered exhaust. So i don't have any so called mufflers. The exhaust was one of the first things i replaced when i got the car. The vacuum canister at that time wasn't hooked up. I wanted it to work to pull the gas fumes away like it was designed to do. I saw that you are from No. Royalton, maybe i will see you and your car around. thanks !
Old Oct 3, 2007 | 08:47 PM
zz4sting's Avatar
zz4sting
6th Gear
Yes i went back and checked the hoses to make sure they were connected. The hose is new so there should be no holes. The only thing i haven't checked was the line coming from the tank to the canister. I have noticed that i don't smell the gas fumes now when i drive. That is leading me to believe the system is working. What guitarcrazy02 says about the less restrictive exhaust sounds good. But you brought up manifold pressure. Could that be fixed by retuning the idle mixture needles on the carburator.?running a 670 holley street avenger
Old Oct 4, 2007 | 06:33 AM
guitarcrazy02
You haven't filled out any of your profile. Where are you from?
Old Oct 4, 2007 | 10:47 AM
Vetteitbe87's Avatar
Vetteitbe87
My 81 does the same thing. If i let off the gas and coast down a hill or downshift to second it will backfire. From what ive heard its pretty normal. Everything on my car checks out so I hope so! Im running hooker headers with stage 2 flowmasters.. so when im comming home at night coasting down my hill the neighbors love it!! haha...
Old Oct 4, 2007 | 11:09 AM
thenuke's Avatar
thenuke
I know my '69 has a vacuum problem and it performs the same way. Letting off the throttle in the mid/high end of the RPM band causes some minor popping/backfiring as it winds down. I also have a slight gas fume smell....and a loud hissing noise when I turn the car off.
I had no idea the vacuum system had this much of an impact!!! I was just ticked, because my wiper door doesn't open. With a vacuum problem, is it safe to be running the car? Could we be causing any damage?
Old Oct 4, 2007 | 11:23 AM
hugie82's Avatar
hugie82
Its your exhaust. Check your manifold gaskets. If they leak a little it will cause back firing.
Old Oct 4, 2007 | 01:03 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I don't think a vacuum leak will do any damage but it can cause the car to run poorly and make headlights, wiper doors, heaters, etc. not work right. If you have a hissing noise when you turn the car off, it shouldn't be too hard to find the leak.
My crusie control quit working last week. It's an old aftermarket unit so I figured it was dead. When I poped the hood, there was a big hole in the vacuum line going to it. I cut off the last 3/4" of the line where the hole was, plugged it back in, and it's good as new.
Old Oct 4, 2007 | 01:14 PM
68/70Vette's Avatar
68/70Vette
When I rev my ZZ4 up (say 3500 rpm) and suddenly let the throttle close to it's idle position, I get an occassional back fire or two as the rpm drops. I don't have any mufflers on the car right now, just headers. The vacuum advance is connected into the intake manifold. I've using a tach drive HEI distributor, but I removed the weights, vacuum can, and electronics that came with the ZZ$'s HEI and installed them in my tach drive HEI.
I've always thought this might be a slight timing or carb jetting problem. I think it's a common problem, I've watch Formula 1 cars sometimes backfire as the drop rpms after a downshift.
Old Oct 5, 2007 | 12:39 AM
Vetteitbe87
Another weird thing that I guess I just realized is also a vacuum problem is when Im driving with the wipers on and I hit the gas hard the wipers just stop where ever they are for about 10 seconds and then resume. Is this just the car giving all its vaccum to the engine? or something I should be worried about?
Old Oct 5, 2007 | 06:29 AM
guitarcrazy02
I don't think wipers are controlled by vacuum, are they? I could be wrong. I know wiper doors on early C3's are controlled by vacuum, but I don't believe the wipers themsleves are.
I seriously think it's your exhaust. Mine never made that popping sound till I put the new exhaust on. Like I said, it's just unburned fuel igniting.
Old Oct 9, 2007 | 09:56 PM
zz4sting's Avatar
zz4sting
6th Gear
sorry i didn't get back sooner.out of state. i'm from mentor. we get out to the solon show on tuesday and mentor's k-mart on saturday.other shows here and there.
Old Oct 9, 2007 | 11:10 PM
PRNDL's Avatar
PRNDL
I had some small leaks in the exhaust system that caused backfiring when I let up on the gas and coasted in gear.
To backfire when engine revs down
