Steering Wheels
Old Oct 4, 2007 | 02:11 PM
mo69's Avatar
mo69
Default Steering Wheels
I've searched the site, but haven't found the answer. Anyone know if a 16" 66/67 steering wheel will bolt right to a 69 hub?
Old Oct 4, 2007 | 02:21 PM
GD70's Avatar
GD70
Why would you want to go to a larger diameter steering wheel? Already tight in there. Just curious.
Glenn
Old Oct 4, 2007 | 02:27 PM
mo69's Avatar
mo69
I like the look of the wood wheel and I thought the deeper dish might give me a little more leg room. (6' 4" with a 4speed)
Old Oct 4, 2007 | 02:36 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
the problem comes from the older wheel 66/67& 68, BTW, the hub had a notch in it for the bottom spoke of the wheel, the 69 & up doesnt. you will have to mod your hub slightly to get it to fit right. other that that though, giddy up
this is a 67 hub, you can see the notch at te 7 oclock position
dont know about more leg room , but the wheel will be closere to you lap for sure,
I sort of climb into my 68
tim
Old Oct 4, 2007 | 03:22 PM
mo69's Avatar
mo69
tim
Thanks for the info, got anymore on the modification?
Old Oct 5, 2007 | 09:10 AM
Trae1976's Avatar
Trae1976
If you're not against installing an aftermarket wheel, you could consider one of Grant's Corvette Series Mahogany wheels. It has a shallow dish, but the smaller diameter may help with leg room.
I have model #794, and am very happy with it:
Old Oct 5, 2007 | 09:21 AM
sweethence's Avatar
sweethence
Unfotunately not, Ive never done it nor have i seen it done,
and as far a using a 67 hub, you would also have to change the horn set up to account for the older style, shouldnt be impossible as long as tyou have all the right pices, but like i say I never put much thought into it.
I like the grant wheel aboyve, but in my case i would have to "fill" in the space to make the wheel work
cheers
tim
Old Oct 5, 2007 | 09:46 AM
Jims79's Avatar
Jims79
16" ouch I'm 6'2" and my 14" wheel still touchs the top of my legs. (I need a tilt column bad).........
To Steering Wheels
