center console question
Old Oct 5, 2007 | 10:45 AM
pwsusi's Avatar
pwsusi
Default center console question
Got a problem and looking for a creative solution. On my '71 the metal shifter console does not screw into the lower center console housing. I looked underneath the top plate....and where it is supposed to screw into the lower console is cracked off on all four corners. Any ideas for how to fix this? I don't want to spend 150 bucks on a new console housing...looking for a creative way to work with what i have.
Thanks,
Paul
Old Oct 5, 2007 | 11:20 AM
Stewart's74's Avatar
Stewart's74
Ecklers sells a repair kit for the tabs. I was skeptical but bought it anyways...it worked!
Old Oct 5, 2007 | 12:26 PM
pwsusi's Avatar
pwsusi
thanks. i'll check it out.
Old Oct 5, 2007 | 12:31 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
The kit is also sold by all the major vendors, so shop around, Also, the directions call for you to use a "hot glue" to secure the metal tabs. My experience was that this did not hold at all. I used JB Weld to secure the tabs, it worked much better, good luck, john
Old Oct 5, 2007 | 05:39 PM
randyward's Avatar
randyward
It seems that the kits are discontinued. Any ideas?
Old Oct 5, 2007 | 05:51 PM
pwsusi's Avatar
pwsusi
i just ordered one from Willcox
There wasn't a picture...hope i bought the right thing
http://willcoxcorvette.com/product_i...ducts_id=16566
Old Oct 5, 2007 | 05:52 PM
RunningMan373's Avatar
RunningMan373
some 'a dem sheet metal flats, with the hole punched in the center of them, shaped like a square "C", when viewed from the side should work.
Old Oct 5, 2007 | 06:08 PM
pwsusi's Avatar
pwsusi
good idea. so how would you attach it to the console housing? glue it?
Old Oct 5, 2007 | 06:46 PM
RunningMan373
Once I got them situated I would JBs weld them, like above. you can JB quick them too, about 1 hour for that,, no strength crit stuff here.
Old Oct 5, 2007 | 09:28 PM
Tewski's Avatar
Tewski
St. Jude Donor '06 thru'17, '23-'26
Zip also carries it. Part number: I-1188
http://www.zip-products.com/Zip/prod...1F795D52F7609E
Old Oct 26, 2007 | 05:18 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We installed the picture of this item for you just now.
Old Oct 27, 2007 | 07:46 PM
vettehed's Avatar
vettehed
just use four long 29 cent J nuts from the hardware store. Just keep the screw pulled up tight while installing it and the nuts will catch under the edge of the console. No need to glue in the nuts.
Old Oct 29, 2007 | 11:51 PM
gmg1977's Avatar
gmg1977
I just fabbed some tabs out of sheet metal. worked for me.
Old Oct 30, 2007 | 12:02 AM
babylonvette's Avatar
babylonvette
i fixed mine with epoxy resin and a little chopped cloth , just mix up a small batch ,and tape up top corners apply batch from underside,next morning you can install top console and drill pilot holes
To center console question
